![]() Drives: 2018 ZL1 Join Date: Sep 2016
NLS yes or no?
For those of you with 800hp or more, are you still using your NLS?
![]() Drives: 1SS Hyper Blue Metallic, MRC, NPP Join Date: Apr 2016
I'm stock and will do a NLS from 3rd to 4th (straight shot) but even at stock power the back end will break loose for a second so if I were at the 800 Hp mark I wouldn't even think about it, unless I was at the drag strip. That would be the only time I'd do it.
![]() Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE Join Date: Dec 2016
NLS after a supercharger is like asking for DEATH, FBO and E85 1st to 2nd was not so "fun". As the car would and can hop like 1/2 car length sideways. After supercharger.. right... good way to die.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
If u can tune the NLS cut off to work it should be ok, otherwise you’d be asking for trouble
