Old 04-23-2020, 07:15 AM   #1
Snakebt6
Drives: Rally Green 2020 ZL1 1LE A10
Dead Battery How to Get the Car in Neutral?
Guys, my battery is dead and I cant get the car started with a jump.
I offered to remove it and bring the battery to the dealer, but they want the car as they want to test the system as a whole.
For my own understanding, (Ive got an A10) how do I get it neutral with no power? Im not sure flat be driver will have an idea?
Thanks
Pat
Snakebt6 is offline   Reply With Quote
Old 04-23-2020, 07:31 AM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
You need enough power to run the car's computers. If the battery is too low then hook up jumper cables to power up the car.
With your foot OFF the brake pedal hold the Start button down for at least 7 seconds. This puts the car in "Run" mode as if the engine was running (even though it isn't). The radio and dash should power up. Now you can put your foot on the brake to make the car release the shift lock and shift the transmission into neutral. Just FYI that if you only hold the Start button down for a few seconds then the car goes into "Accessory" mode where the radio works but the car won't release the shift lock.
Good luck with the car!
Mark114 is online now   Reply With Quote
Old 04-23-2020, 07:58 AM   #3
Snakebt6
Thanks much appreciated!!
Old 04-23-2020, 09:59 AM   #4
~Jb
~Jb's Avatar
Drives: 2018 ZLE
Don't all autos have a manual release? Owners manual will tell you where. Typically near the shifter.
2018 ZL1 1LE (CARBON/PDR/NAV)
~Jb is offline   Reply With Quote
Old 04-23-2020, 10:33 AM   #5
Snakebt6
Thanks Ill look.
Any harm if I have to turn the wheels? Not sure a flat bed is going to get into my driveway and be able to back in to get it out of the garage?
Im thinking ive got to push it out and turn it 90deg. So the flat bed can get it.
Old 04-23-2020, 12:42 PM   #6
Indy_62
Drives: 2017 2SS / 2003 S10 Crew Cab
The first portion of this video is what you need to do:
Never say never!
Indy_62 is offline   Reply With Quote
Old 04-23-2020, 12:50 PM   #7
Mark114
Mark114's Avatar
No, no harm in turning the wheels. It will just be more difficult without the power steering assist. If your driveway is on a slope then be prepared for the brakes to take more pressure without power assist too.
Old 04-23-2020, 03:02 PM   #8
Snakebt6
Thanks guys.
Ill need to move it into neutral manually as its so dead nothing happens now when you put jumper cables on it.
Its a 1LE and the seat doesnt fold down I dont think (I looked and didnt see anything to pull it down with) so how do they even get to the battery?
Also without the Tow Eye (also in the trunk) is there a safe place to pull it up onto the flat bed from?
Sorry for the 21 questions
Old 04-23-2020, 04:48 PM   #9
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Why don’t you take the battery out and take it to them to test. If it’s no good then have them give you a new one. Install it then drive it to the dealer for further diagnosis as to why it’s completely dead. If that’s exactly the problem. It eliminates the flatbed. Unless the dealer is too far to make the couple trips back and forth.
Just strange the battery would be that dead on a 2020 vehicle.
Old 04-23-2020, 05:07 PM   #10
Mark114
Mark114's Avatar
The ZL1 1LE rear seat does fold forward. The posts at the end of this thread look like you can release the latch from inside the car with a trim tool.
https://www.camaro6.com/forums/showthread.php?t=527575
If you can't get the seat down then maybe contact the dealer before the flatbed arrives to see if they will loan you a tow hook from one of the cars they have on the lot?
Old 04-24-2020, 07:37 AM   #11
Snakebt6
I agree about a new battery being dead.
Im good though, got in the trunk and removed the battery and took it to the dealer.
I was going to have it towed as they wanted the whole car but spoke to the service advisor and told him I wanted just take him the battery and not go through the hassle of tow.
Even OnStar just told me it was dead lol.
They have it now and will get me a new battery later today.
Thanks guys.
Old 04-24-2020, 09:02 AM   #12
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Can you please provide some useful info for the rest of us...
Did you try the trunk release with a charger or jump battery hooked to the terminals under the hood?
How did you finally get to the battery?
17rsvert is offline   Reply With Quote
Old 04-24-2020, 09:46 AM   #13
Snakebt6
Sure..
The car was completely dead when I tried to jump it with another car. Zero in the way of any life.
I actually went and bought a portable jumper. Its a battery operated one but also has a plug in option as well.
That got power on everything and I was able to open the trunk.
Ive got the new battery installed and all is right with the world now. :-)
