Old 04-23-2020, 07:56 AM   #1
BH1
Drives: 2016 2SS M6
Water temp drops and fans come on
My water temp gage drops to the floor, the cooling fans come on and active rev match turns off. Turn off the car and the fans remain running until I disconnect the battery. I thought it was the thermostat, so I decided it’s a quick fix and took it to the dealership the next day.
Fans come on as soon as I start it in the morning and the temp gage remains on the floor. I have a p3 gage and the coolant temp is great, so is the oil temp. On the 4 mile trip to the dealer, the the temp gage comes back online and the fans go off, but an engine light comes on.
They replace the thermostat and everything seems ok for 4 days. Then same thing happens again today. Coolant temp is good, oil temp is good. Thoughts?
BH1 is offline   Reply With Quote
Old 04-23-2020, 08:43 AM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
It sounds like a problem with the wiring harness to the temperature sensor. Maybe a loose connector or the harness has an intermittent short someplace from rubbing. Check the connection to the temperature sensor and the wiring harnesses near the fuse box in the engine compartment.
Old 04-23-2020, 08:49 AM   #3
BH1
Drives: 2016 2SS M6
Thanks Mark114. I’ll give it a look.
Old 04-23-2020, 12:03 PM   #4
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
My problem was exactly this! Bad electrical connection.
Wiring harness to the Temp sensor (rectangular connector): in my case, it happened to be one of inside metal connects "tweezers" that lock onto the sensor's connects: One of them loosened up and gave an intermittent signal to the ECM.
Fix was simple - took long nose pliers and carefully pressed together the connects to form a better lock on the sensor's connects.
Such false signal triggers "cooling safe mode", which results in the following phenomena:
1.) Rad. Fan on full blast all the time (and continues to work for ~ 8 mins. even after shutting off the ignition).
2.) Cluster's temp. gauge pegged to Min.
3.) AC compressor will not engage = no more Aircon.
4.) CEL fault lights up (can be erased with Diagnostics tool)
Old 04-24-2020, 08:31 PM   #5
BH1
Drives: 2016 2SS M6
Thanks Eldi Z!!
Old 06-10-2020, 11:14 AM   #6
GTIanZ28
Drives: 2016 V6 RS Camaro 6MT
I’m having this exact same issue.
Mine is a V6 though. How do I figure out which of the 10 or so connectors is the temperature sensor?
I fiddled with all of them yesterday to make sure that they were properly seated. This has been an intermittent issue, but now it seems stuck in this fan on 100% mode.
I almost bought a new thermostat/housing. Know how to do something that simple. Was also considering replacing relays.
But, I’d like to try this connector fix first.
Edit: I have a diagnostic tool to delete codes as well.
Edit #2: found a pretty good post with multiple people having the same issues with both V6 and V8’s. They claim that it’s 2 possible things. Bad temp sensor or bad thermostat.
https://www.cargurus.com/Cars/Discus...59580_ds984204
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
GTIanZ28 is offline   Reply With Quote
Old 06-10-2020, 09:10 PM   #7
Shadyredeyes
Drives: 1996 SLP Z28/SS #1326
Mine did the same thing. Had a leak at the thermostat housing. Replaced that and the thermostat. Bam. Problem gone.
Shadyredeyes is offline   Reply With Quote
