![]() Drives: 18 ZL1 - M6 Join Date: Mar 2019
Quickjack Stuck
Hey everyone,
Has anyone had the issue of one/both of the quickjacks getting stuck in the upward position? I only used my set a few times so far and one is now locked in the lifted position. I’ve reached it to QJ and the feedback is very slow. Perhaps is QJ is looking, they can chime in. I’ve been emailing a rep named Cynthia. After taking her advice and trying several thing, I’m more than frustrated with this. The only good news is that my vehicle was not on it when it got stuck. However, I noticed the issue (creaking noise and very slow lowering) while my girl was up on it. Once I thankfully got her down, I raised the lifts up and now one won’t come down. Any help is greatly appreciated. Thanks everyone!!
#2 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Cynthia / QuickJack tech support are usually pretty quick to respond to questions or at least they were for me. They may be on reduced hours or reduced manpower due to current situation so maybe be a little patient with them. One of mine had a noisy seal and they replaced the hydraulic jack, but otherwise has been flawless.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
![]() Drives: 2017 2SS Manual Join Date: Apr 2017
#5 | ||
Thanks for the feedback. I'd like to first start by saying that I "don't" use these lifts without a vehicle on them. As I mentioned, I noticed a creaking noise coming from one of them while lifting / lowering them. I felt it best to get my vehicle off the lifts and go through the "setup" process again as seen in this video: In doing so, the lift went up, up and up. But not down in any way. The first representative that I spoke with stated that there needs to be at least 300# on the lift in order to give it a good cycle. NO problem there because I stacked several bags of softener salt, PLUS I was standing on it with no luck getting it to come back down. What I've noticed is, when I charge up the air cylinder between 40 - 50 PSI, it's only a matter of minutes before it's back down to 0. I think the air is leaking past the seal on the gas cylinder. vtirocz, it's possible that the same issue that you had is what I'm dealing with. However, my hydraulic jack may be too far gone, for whatever reason. Again, It's been less than a year since I've owned these and I've "maybe" used them 4 - 5 times since purchasing. I still like the lifts / concept. However, in their current state, they're useless. Thanks again for all the feedback / ideas guys. I'm hopeful that QJ will be back with me soon for resolution. |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
It's mentioned six times in the manual not to do that. Remove the hose fitting on the cyl slowly to bleed off oil. Also in the manual you need to lube the pivot points often or they rust and get cranky. Check the Schrader valve (core) and make sure it's tight and not leaking down.
#7 |
Drives: Camaro 1LE Join Date: May 2018
I was told by quickjack to never go past the halfway point without a vehicle on the lift. When I lube mine up (twice a year), I'll cycle it a handful of times and so far no problems. Mine also loses air pressure on the cylinders that help lower the unit and have since I bought it. With that said, mine will still lower just fine but to be safe, I'll add air anyways before I use it. I should try some new valve cores and see if that's the fix or not.
Op, another thing to check is your fluid reservoir breather. I've forgotten a couple of times to open it before use. That could prevent the lifts from lowering. The other thing to try is just start stacking weight on the lifts with anything and everything, or a couple of people on each one. |
#8 |
Thanks everyone for the feedback / ideas. As of now, I've tried just about everything, including what QJ Technical Service suggested. SilveradoSS, that's a good call about opening the pump vent. I can see how that would definitely be an issue when trying to lower them. After pressurizing it to 45 psi, I've stacked 4 salt bags and stood on this thing (nearly 350#) while pushing the down button and I can get this thing to budge at all. For whatever reason, it's not moving at all. I'm convinced that there's something wrong with the lift cylinder. But for the little use and the fact that I've taken good care of this system, I can't tell you why. Perhaps it was the luck of the draw. Regardless, I'm waiting to hear back from QJ and will let everyone know their response / resolution.
Be safe out there... |
#9 |
![]() Drives: 2016 camaro ss Join Date: Sep 2015
I got both of mine stuck the first time I used it, mine never came with the big warning page saying not to put them up without a vehicle.
I pulled the hoses off the jacks, cracked open the bleeders and stood on the jack and hit it with a rubber mallet, once it moved enough it came down on its own. This made a hell of a mess in the garage since fluid will come out of the bleeder as you hammer it. |
#10 | |
#11 |
L8ap3x
What a problem.
Up is always better than down Wife is a happy woman I bet! Lol. |
#12 |
Drives: 2015 Camaro Join Date: Aug 2018
I'm wondering.....are these things made in China?
#13 |
