Old 04-16-2020, 07:34 PM   #1
blk 2013
blk 2013's Avatar
Drives: 2017 SS 6sp
lazy ss
I have a 2017 1SS 6sp with ported intake ported TB rotofab and axle back exhaust car seems lazy to me or I maybe getting use to it. is it time for a tune?
blk 2013 is offline   Reply With Quote
Old 04-16-2020, 07:46 PM   #2
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
You are probably just getting used to the power, I did haha.
The only way to fix your issue is "MO POWAH BABY!"
soloknight6 is offline   Reply With Quote
Old 04-16-2020, 08:43 PM   #3
Xaxas
Xaxas's Avatar
Drives: 2019 2SS 1LE
Did you perform the ECM relearn procedure? There could also be a leak somewhere
Current: 2019 2SS 1LE aka "Blanc"
Previous: 2017 2LT aka "Noire"
Mods: Chevrolet Performance Suspension || K&N Cold Air Intake || Borla ATAK Mufflers + Catback system || MRR 650 ZL1 replicas with squared 285/30 Michelin Pilot Sport 4S || ZZP 4 piston brake kit + braided brake lines || BMR everything (Solid/Lockout cradle bushing are a MUST in Camaros)
Xaxas is offline   Reply With Quote
Old 04-16-2020, 10:21 PM   #4
Try the Soler throttle body instead (you should be able to send your TB in for rework), and if the car's still "lazy", add their throttle controller. You will thank me later
After that, however, it's indeed moar powa' baby time. And more tire baby. And... and...
Old 04-17-2020, 11:32 AM   #5
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
This is a common issue and not only for Camaros, but the horses are there, they just need to be whipped.
A tune will be good if you don't have warranty concerns. Other than that, and not instead of a tune, but on top or simply as stand-alone Mods w/o tune, you could try our ways and be more than pleased. Check us out, e-mail or call if you have any questions.
Thank you...and thanks, Arpad for your recommendation.
Tiffany,
Soler Performance LLC,
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
Mike@SolerPerformanceLLC is offline   Reply With Quote
