![]() Drives: 2016 comaro ss Join Date: Mar 2018
2016 2SS Convertible: Conv top slide arm covers
For anyone that has a 2016 comaro conv, I have heard that the conv top arm slide covers may fail to come back to a covered position. This can be caused by a spring failure or a slide groove failure. I found that you can purchase the replacement inner upper panel part for about 80.00 to 100.00 dollars. This replacement part includes all the pieces needed in a single part number.
The replacement part however has an additional clip that was not on the original part. I suspect it was added due to added support for the spring system that pulls the cover back in place. This new part has an additional clip that You will need to create a new slot for. I used a drill to create two holes which I then combines to create the slot in the current bracket this part connects to. Be sure to measure the location of the additional clip so you can create the additional slot accurately. |
![]() Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
Can you post a pic of the slots you created?
From what I understand the additional clip is designed to fit in a slot in the redesigned window regulator housing that needs to be installed replacing the older style one. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
| Tags |
| 2016, convertible, slide cover |
