Old 04-15-2020, 03:47 PM   #1
hfur
Drives: 2017 Chevy camaro
Big block or small block?
quick question...Don't laugh...is the 6.2 liter (376 cid) V8 455 in this camaro considered a small or big block?
hfur is offline   Reply With Quote
Old 04-15-2020, 03:56 PM   #2
retmil
Drives: 2022 Wild Cherry SS
Small block.
retmil is offline   Reply With Quote
Old 04-15-2020, 05:41 PM   #3
6spdhyperblue
Drives: 2SS 1LE
Pontiac
Old 04-15-2020, 06:40 PM   #4
s346k
s346k's Avatar
Drives: like an old lady
Originally Posted by 6spdhyperblue View Post
Pontiac
421? 428?
Old 04-15-2020, 06:56 PM   #5
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
421? 428?
455
soloknight6 is offline   Reply With Quote
Old 04-15-2020, 07:17 PM   #6
s346k
s346k's Avatar
389?
Old 04-15-2020, 07:29 PM   #7
oldman
Drives: SS 6 speed of course
Pontiac had only one engine size (external dimensions) and it was a big block. Literally large externally. 4.62.
Small blocks like the Ford 302 and Chevy 350 had 4.40 bore spacing (3.80 for Ford) so this and anything smaller like the 4.6 mod motor are all small blocks. Even though internally both Ford and Chevy delivered 400 cid small blocks.
The Rat is 4.84 and since the cid goes up with the radius squared big bores = BIG engines. Stroke for a gas car engine is pretty much limited to 4 inch.
Old 04-15-2020, 08:11 PM   #8
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by soloknight6 View Post
455
389?
Pffft... 301 turbo bitches!
Old 04-15-2020, 08:37 PM   #9
s346k
s346k's Avatar
326?
Old 04-15-2020, 11:13 PM   #10
95 imp
Dumb Ass Deluxe
400?
Old 04-16-2020, 12:01 AM   #11
HighIron
Drives: 2024 2SS Summit White
I don't know. Compared other engines "back in the day", I've always thought Pontiac V8s were fairly compact compared to their displacement, especially in the above 350 cubic inch range. So many other of the large CID engines from other makes seemed enormous and bulky compared to a Pontiac.
HighIron is offline   Reply With Quote
Old 04-16-2020, 01:26 AM   #12
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
the 6.2l (376ci) isnt even a large small block. They Stopped making a big block in 2009.
Old 04-16-2020, 01:28 AM   #13
oldman
All related to bore spacing. The line has to drawn somewhere and that is 4.40 bore spacing making the mouse the largest small block. But you are correct from memory the Pontiac was the smallest externally “Big Block”, so it is closer in size to the mouse. The Ford 302 is really a tiny engine.
Old 04-16-2020, 09:38 AM   #14
DorkMissile
DorkMissile's Avatar
Drives: DZ
I think he meant the 6.2L 376ci 455HP LT1
In the end, it is the 5th generation Chevrolet small block
DorkMissile is offline   Reply With Quote
