Old 04-14-2020, 04:13 PM   #1
Clearly_Canadian
Clearly_Canadian's Avatar
Drives: 2017 2SS Camaro
rad hose collapse
I am assuming this is normal, however, I have never noticed it before. I was detailing my engine bay and noticed my upper rad hose was fully collapsed. Any Idea why? Car is running fine, I am just curious.
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
Clearly_Canadian is offline   Reply With Quote
Old 04-14-2020, 04:36 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
they usually have a spring inside of it maybe it got damaged or worn over time id just remove it and replace it
samco makes some nicer ones if you want to upgrade up to you!
https://www.samcosport.com/
Old 04-14-2020, 04:42 PM   #3
Wierd Harold
Drives: 2017 2lt rs
This is a sign of low coolant level how is the level in the coolant tank
Wierd Harold is offline   Reply With Quote
Old 04-14-2020, 04:54 PM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
That seems unusual. The radiator cap will let the system pressurize but I don't think it should allow a vacuum to form. Under vacuum the system should draw fluid from the reservoir which isn’t sealed. You might want to have the cap checked.
Old 04-14-2020, 05:27 PM   #5
caSStro18
Drives: 2018 Camaro SS
Yes. Most likely the radiator cap is the culprit. Because, that ain’t normal!
caSStro18 is offline   Reply With Quote
Old 04-14-2020, 08:20 PM   #6
Yellow Beast
TD
Yellow Beast's Avatar
Drives: 2017 2SS, 2014 Mercedes C300
Is this on your Camaro? Either way its not normal. You have an issue with coolant pressure. Possibly a stuck thermostat, low coolant because of a leak, radiator cap, I don't want to go down the headgasket road yet. Get it checked out. Hopefully its something simple. Let us know .
Yellow Beast is offline   Reply With Quote
Old 04-14-2020, 09:25 PM   #7
Clearly_Canadian
Well, who woulda thunk... Bottom reservoir was completely empty and the top was only half full. I have been driving new vehicles for 15 years and have never had to actually check coolant levels. Didn't even dawn on me. On the bright side now my reservoir is two different colors. The only open station near me didn't have the pink dexro stuff. Only the yellow 50/50 Pennzoil.
I guess I will have to monitor this a little closer. I had my oil changed a few weeks ago, I was told all the fluids were good. Mind you, that is if they actually checked it. Knock on wood I don't have any leaks. She hasn't been running hot.
Old 04-14-2020, 09:31 PM   #8
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
You are very fortunate and lucky your Camaro didn’t have major problems or a complete meltdown before you found the low coolant issue!��
Old 04-14-2020, 09:43 PM   #9
Clearly_Canadian
I assume too much. I know that. But why didn't I get a low level message? I mean, it bloody well lets me know when my shoe lace still has the clutch engaged 1/16 of an inch for longer than 3 seconds but it wont let me know of my critical's?
Old 04-14-2020, 09:55 PM   #10
Yellow Beast
TD
It won't let you know your coolant level is low. If the coolant is really low it will overheat and the temperature guage will go up. Coolant doesn't evaporate. If your reservoir is low, you have an issue. A leak somewhere or an overheating issue. Maybe its just a hole in the reservoir which I doubt but its possible.
Old 04-14-2020, 11:01 PM   #11
95 imp
Dumb Ass Deluxe
99.9% of the time only the lower hose has a spring in it to keep it from collapsing because it is the intake. The upper hose is always under pressure. More than likely, your hose did that because of the thermodynamic change when you got everything wet. (From the pic, it looks like it is wet and I'm guessing you washed the engine and/or radiator).
Once it warms back up (engine temp, not outdoor temp) it should fill back out.
Old 04-15-2020, 03:25 AM   #12
cdrptrks
cdrptrks's Avatar
FYI the manual's wording suggests that low coolant is an expected condition from normal use ("when it is low" not "if") that should be checked for (pages 271-276). There are plenty of people who have posted in this thread that found low coolant without any other adverse symptoms from their car. I actually checked my own car after reading that thread last year and found that I needed to add some coolant to both the top and bottom tanks. Or maybe the factory is not filling the coolant to the correct levels on some cars.
Old 04-15-2020, 05:59 AM   #13
cmfhsu
Drives: 2019 2SS 1LE
I have had to add about 2 quarts of coolant in my 10k miles of ownership to the lower reservoir. I drive during the cold months of the year too, so my usage may be a bit unusual.
cmfhsu is offline   Reply With Quote
Old 04-15-2020, 09:09 AM   #14
buck50
Drives: 2021 C8, 2022 Camaro 2SS
Originally Posted by Clearly_Canadian View Post
Well, who woulda thunk... Bottom reservoir was completely empty and the top was only half full. I have been driving new vehicles for 15 years and have never had to actually check coolant levels. Didn't even dawn on me. On the bright side now my reservoir is two different colors. The only open station near me didn't have the pink dexro stuff. Only the yellow 50/50 Pennzoil..........
Sound to me like you added non-Dex-cool coolant with factory fill dex-cool.
Not a recommended thing to do. Google it and you'll read all kinds of reasons why not a good idea.
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022
3400 1/25/2022 TPW 1/31
3800 2/15/2022
4300 2/19/2022
4B00 3/04/2022
4000 3/8/2022
Delivered 3/9/2022
____________________________________
Order 6/01/2016 2017 2SS, NPP, 56R whls
3000 6/08/2016
3000 6/15/2016 TPW 7/18/2016
3400 7/7/2016
4200 7/25/2016
Delivered 7/28/2016
Sold May 2020
buck50 is offline   Reply With Quote
