Old 04-13-2020, 07:37 PM   #1
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
After oil change stink
So seems like every time I change the oil. The car stinks like burned oil for a week or so, only while driving. I have a lift, so I dont have any spillage on the outgoing fluids underneath. I know I didnt spill any when filling either. I have a special long funnel to avoid and spills in the engine bay. Oil level checks as good.
Even when the dealer does it, same results. It smells like burnt oil for a week or so?
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 04-13-2020, 07:45 PM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
There is chance to spill on the cross brace from the filter, maybe you are getting some there?
Suggest you get one of these if you want to limit spillage from drain: https://www.stahlbus-us.com/oil-drai...steel-set.html
Old 04-13-2020, 11:09 PM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
+1 for the Stahlbus valve. Makes taking samples for Blackstone a breeze!!
...and no stink...
Old 04-13-2020, 11:36 PM   #4
Junkyardspecial
Junkyardspecial's Avatar
Drives: 2018 ZL1 1LE
Wipe the pan down after you change, youre probably spilling oil on the motor and letting it burn off.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial
Will buy your GoodYear Supercar 3R Take offs!
Junkyardspecial is offline   Reply With Quote
Old 04-14-2020, 11:19 AM   #5
Vigilante375
Drives: 2018 Camaro ZL1
It could be from the oil filter change out or oil pan drain plug if you're sure that you didn't spill any from the top.
You can wipe the pan and oil filter area visually clean, but it's still there. If you use something like alcohol wipes or whatever to clean it then it should get it off.
Old 04-14-2020, 12:14 PM   #6
Snowwolfe
Drives: CTV5 V Blackwing on order
This was a common problem on C6 corvettes. I don't think they ever truly proved what caused it but a lot of owners said if they poured the fresh oil in slowly the issue decreased.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 04-15-2020, 08:40 AM   #7
PROMETHEUS
PROMETHEUS's Avatar
+1 on the Stahlbus valve. It drains a little slower, but no mess is well worth it!
Old 04-22-2020, 10:35 PM   #8
Pupilbone
Pupilbone's Avatar
Drives: 2019 Crush ZL1 M6
Great idea, ordering...
#SaveTheManuals
Pupilbone is offline   Reply With Quote
Old 04-23-2020, 10:12 AM   #9
dbvettez06
Drives: 2001 corvette Z06. 2018 ZL1
I also have spelled this. Kind of like oil burning somewhere but it goes away in time.
dbvettez06 is offline   Reply With Quote
Old 04-23-2020, 09:16 PM   #10
Badmojo
aka BeastZL1
Badmojo's Avatar
There are two sources of oil drips:
1. Filter oil on the aluminum cross brace (it's on the top and blows onto the cats)
2. Checking the oil on the dipstick. Just a drip or two onto the header heat shields takes FOREVER to burn off and stinks for 500 miles.
Solution:
1. Spray the oil pan and adjacent areas with brake cleaner.
2. Put a rag around the top of the dipstick tube BEFORE you pull the dipstick.
3. Go to road course track day and burn all the oil off in 15 minutes.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
