Old 04-13-2020, 12:25 PM   #1
Bain
Drives: 2019 Shadow Gray Metallic ZL1
ZL1 305 Tire Matrix
In my search of tires for our 19 ZL1 I compiled the following spreadsheet comparing all the 305/30/20 tires Tirerack sells for comparison. The ratings are directly from the tests Tirerack conducted and found on their site.
I figured this may help someone looking for replacement tires. Hope this helps pick the best tire for your application
I also added some tires for size comparison even though they were not tested.
Bain is offline   Reply With Quote
Old 04-13-2020, 02:27 PM   #2
Alponcho
Drives: 2018 Camaro ZL1
Thank you. Interesting how close the PS4S and PSSS are, and how much better the Michelins are across the board in comparison to the factory GY.
Alponcho is offline   Reply With Quote
Old 04-13-2020, 03:23 PM   #3
HypeBlueZL1
Drives: Chevrolet Camaro ZL1
Cool chart thanks for putting that together. Note the RE980AS is the only all season tire on the list. Unfortunately they don't make 285s to fit the front.
HypeBlueZL1 is offline   Reply With Quote
Old 04-13-2020, 04:17 PM   #4
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
Thank you ! I'm getting ready for tires in the next few months.
Revalot is offline   Reply With Quote
Old 04-13-2020, 04:20 PM   #5
AZ_1LE
Drives: 2019 ZL1 1LE
Pilot Sport 4S's getting a better dry traction rating than the Sport Cup 2's? Oh come on, fanboys
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 04-13-2020, 11:24 PM   #6
GrimReaperSS
Drives: 2001 Onyx Black/Ebony SS. 427/M6
Unfortunately the Continental Sportcontact6 isn't available in the front size. On the Continental hierarchy, it is the higher performance model compared to the Extreme Contact Sport. Although with a 240 UTQG, it won't last as long as the 340 UTQG Extreme Contact Sport. If anyone here is a bit of a tire geek as I am, I recommend stopping at the tire manufacturer trailers/displays at races or even air shows. I had the opportunity to do so last year at EAA Airventure in Oshkosh last summer at both the Continental and Michelin displays, the Goodyear one was set up for aviation only. The typical sales people are out front giving away swag, but there are tire engineers around as well and don't seem to get a lot of real tire questions from people. They kinda jump for the opportunity to talk to someone, maybe it was because I was at an aviation show.... (Most everyone just wants to check out the sales ladies, I don't blame them). It's one thing to research online etc, but its pretty cool to get to talk to the people that R&D them too.
GrimReaperSS is offline   Reply With Quote
Old 04-15-2020, 09:16 PM   #7
Bain
I’m not recommending any tire, Just sharing the information that was posted by Tirerack
I did however just buy a set of PS4’s for daily use. I was mainly concerned with wet conditions.
Old 04-15-2020, 10:01 PM   #8
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
Don't see the Toyo R888R on the list. I don't care much about wet conditions my doesn't see rain. I want dry traction. Going with the R888R for this summer tire 315/30/20 in the rear
Zigg L1 is offline   Reply With Quote
Old 04-15-2020, 10:26 PM   #9
Flexhorn
Drives: A10 ZL1
You will need spacers and to relocate the drivers side harness for the Tokyo’s from what I’ve read. I have them but haven’t put them on yet since tracks are closed.
Flexhorn is offline   Reply With Quote
Old 04-15-2020, 10:39 PM   #10
~Jb
~Jb's Avatar
Drives: 2018 ZLE
What are the ZLE owners chopped liver?
2018 ZL1 1LE (CARBON/PDR/NAV)
~Jb is offline   Reply With Quote
Old 04-15-2020, 11:18 PM   #11
Markoz28
Drives: 18 ZL1 nightfall grey A10
Move the harness, yes. Spacers, no. You will be just fine without them.
Markoz28 is offline   Reply With Quote
Old 04-16-2020, 08:53 AM   #12
Snowwolfe
Drives: CTV5 V Blackwing on order
I suspect within a year we will see more quality choices for the ZL1 as the C8 has the same size rear tires as our car.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 04-16-2020, 09:30 AM   #13
Junkyardspecial
Junkyardspecial's Avatar
Drives: 2018 ZL1 1LE
Dont they make Supercar 3R in the regular ZL1 size now?
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial
Will buy your GoodYear Supercar 3R Take offs!
Junkyardspecial is offline   Reply With Quote
Old 04-17-2020, 01:00 PM   #14
2ltrgsr
AXLERODZL1
2ltrgsr's Avatar
Drives: 2019 Riverside blue ZL1 Camaro
So Nitto just released the NT555RII Drag Radial Tire... which they actually used to make years ago.
Competition Performance
The sidewall construction has been modified to improve launch for better 60’ times*.
*Compared to NT05R.
Contact Patch
The large twin center ribs provide a continuous contact patch for dry traction.
Race Compound
NT555RII features race compound for increased traction at the starting line.
size
305/30R20
P/N 108560
Tread Depth 6.3
Diameter 27.24
Overall width 12.32
Approved width range 10.5-(11.0)-11.5
Load 1929
PSI 50
Weight lbs 31.75
'19 ZL1 A10 Riverside Blue PDR/Nav/Sunroof
Kong ported blower/snout
Roto-Fab Big gulp
103 TB
Lingenfelter Lower Pulley(9.17)
1 7/8 ARH headers and Exhaust
Meth injection(single nozzle)
733whp/788tq
2ltrgsr is offline   Reply With Quote
