![]() Drives: 2016 Camaro 2SS M6 Join Date: Aug 2014
SS w/ 6-Piston Brembo kit - Aftermarket Rotors?
Hey guys, the time has come to do pads and rotors on my SS, and I was easily able to find rotors for the rears, but I cannot find front rotors for the life of me. I currently have the 14.6" slotted and vented rotors from the LPO big brake kit. Anybody found aftermarket rotors for these yet? Thanks in advance.
Ordered: Red Hot 2016 Camaro 2SS coupe M6 (8/22/15)
3000: 8/27/15 TPW (10/19): 8/31/15 3300: 10/8/15 3400: 10/10/15 3800: 10/21/15 VIN #118558 5000: 1/4/16 @ 11:49AM 6000: 1/4/16 @ 11:49AM |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
There is a sticky in the 1LE section about these I'm pretty sure.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
I see the one about brake pads that's stickied, but not about rotors
No aftermarket companies make a 2 piece rotor replacement
Here's some choices: Standard SS 1LE rotors (comes with ring and hat assembled) ACdelco # 177-1193 and 177-1194 (much cheaper that the GM slotted ones) usually RockAuto has the best price (they use # 1771193 and 1771194) Other choices are buy replacement rings and swap the hats. Best place to get rings are from Ken at KNS brakes. Price wise both are about the same but the rings are slotted. |
#5 | |
They are the same size 370 mm x 34 mm and use the same calipers and brake pads
#7 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
You might not be able to find complete replacement rotors, but KNS does sell replacement rotor rings...
https://www.knsbrakes.com/c/car-seri...-+Single+Rotor
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
