Old 04-12-2020, 02:09 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
wtb a shifter detent tr6060 or t56
i want to get one to try and put a lighter spring in it for the hurst shifter. something better then the anti venom mod.
Old 04-12-2020, 08:17 AM   #2
DorkMissile
DorkMissile's Avatar
Drives: DZ
It might be worth giving Tick a call - if anyone knew anything about it, they might.
You could take it apart, cut a coil or two off, stretch it out to about the same length and that would soften it up also.
DorkMissile is offline   Reply With Quote
Old 04-12-2020, 08:40 AM   #3
6spdhyperblue
Drives: 2SS 1LE
How do u get it apart
Old 04-12-2020, 11:22 AM   #4
JCunningham
Drives: 2017 2SS M6
cut it. putting it back together id have to figure out.
Old 04-12-2020, 11:28 AM   #5
6spdhyperblue
Drives: 2SS 1LE
Oh man. Interesting. Wonder if the top where the spring seats can be drilled out and then threaded so we can drop the modded spring in there and thread on a cap or weld it?
Old 04-12-2020, 12:21 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I bet it’s just pressed in and lock-tited. Maybe a heat and a screwdriver?
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 04-12-2020, 11:39 PM   #7
blk 2013
blk 2013's Avatar
Drives: 2017 SS 6sp
whats wrong with adding washers?
blk 2013 is offline   Reply With Quote
Old 04-12-2020, 11:48 PM   #8
JCunningham
Drives: 2017 2SS M6
the stick flops around and makes it harder to find gears. Im down to 1 thin dorman copper washer and you can hear it tapping the ball bearing a idle. the shifter needs a little resistance on it. with the any washers its not touching the shifter so it will just flop around . With the 1 washer 1-4 feel ok but 5th feels like your putting it in reverse and its harder to find because the resistance is so much more. if there were no washers and the detent had a weaker spring all gears would feel the same.
