Old 04-11-2020, 04:32 PM   #1
orange blaze
Red Hot SS
orange blaze's Avatar
Drives: 2017 Camaro 2SS
will they fit
Looking at the ZL1 replica wheels for my 2017 Camaro ss. The fronts are 20x10" 40 mm offset. The rears are 20x11" 43 mm offset. Now the rears should be fine except the harness on drivers side. The fronts is where i need some advice. If i add a 10mm spacer or maybe a 15mm adapter would those wheels fit by the front strut and would they poke past the fender well? Pictures if you have any of this setup. Tires i would like to use would be 275/35/20 up front and 315/30/20 in the rear.
orange blaze is offline   Reply With Quote
Old 04-11-2020, 11:57 PM   #2
Kerry
Drives: 2019 2SS Camaro
you will need a 15 to 20 mil spacer I would go 20. 10 is no good as studs are not long enough for me. 15 for no poke.
Kerry is offline   Reply With Quote
