Old 04-11-2020, 04:21 PM   #1
tx915zl
tx915zl's Avatar
Drives: 2017 Camaro zl1
What went wrong
I own a manual 2017 ZL1. I took in into the stealership because of a noisy supercharger. Dealership said it did a new upper pulley, so they replaced it u under warranty. Not that I have the car back, it seems that the supercharger whine is a lot quieter than before and the car does not to pull as hard as it did before, through any of the gears. What gives? Anyone have any idea why this would have happened? Is there anything else that might be wrong with it. Only mods are k&n CAI n ported throttle body. Thanks in advance
tx915zl is offline   Reply With Quote
Old 04-11-2020, 04:37 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Air in the SC coolant loop will cause the pump to cavitate and shut down boost. No codes will be thrown.
Bleed the SC loop.
https://www.camaro6.com/forums/showthread.php?t=523702
https://www.camaro6.com/forums/showp...8&postcount=12
Old 04-11-2020, 06:21 PM   #3
Pantherzl1
Drives: 2019 Camaro zl1
These idiots probably didn’t bleed the super charger after. Make sure you bleed it
Pantherzl1 is offline   Reply With Quote
Old 04-11-2020, 08:56 PM   #4
Nev3rL8
Drives: GTO
so the SC needs bleeding every time the pulley is replaced?
Nev3rL8 is offline   Reply With Quote
Old 04-11-2020, 09:43 PM   #5
Gunkk
Gunkk's Avatar
Pretty sure you cannot change the pulley block bearing with the SC on the car.
Old 04-12-2020, 02:39 AM   #6
tx915zl
tx915zl's Avatar
I’ll be taking back to the dealership and ask them to bleed the lines, thanks for the responses.
Old 04-12-2020, 11:12 AM   #7
Nev3rL8
Drives: GTO
Good to know, thanks.
Old 04-14-2020, 10:34 AM   #8
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
I do not track my car. How would I know if I need to do this procedure? The car definitely has a drop off in power in hot weather. Thanks.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 04-17-2020, 05:23 PM   #9
tx915zl
tx915zl's Avatar
Had the service performed and no change. It still doesn’t feel the way it should, what gives? Any other ideas, what could be causing the issue?
Old 04-17-2020, 05:34 PM   #10
FoundNemo
Drives: 2019 ZL1
Check the bypass valve set screw, post a pic up and I'll have a look for you. What is your boost gauge peaking at on a WOT hwy pull?
As noted, take it back and make them bleed the supercharger coolant pathways. Or get the edelbrock reservoir and do it yourself.
FoundNemo is offline   Reply With Quote
Old 04-17-2020, 05:59 PM   #11
PROMETHEUS
PROMETHEUS's Avatar
Get the ADM performance LT4 SC reservoir and you wouldn't have to worry about air in the lines. It takes less than a hour to install and it is well worth the money, plus it gives you a little more coolant.
Old 04-17-2020, 10:25 PM   #12
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
Good advise.
Stefano is offline   Reply With Quote
Old 04-18-2020, 10:37 AM   #13
Juiced1
Drives: 2012 2SS CAMARO 45th
A reservoir goes a long way. If you don't have one its very easy for an air bubble to shut down your pump. No pump means sky rocketing intake temps and no power. I can't stress enough how many dealers skip the bleeding process. Nearly half of the cars don't have any fluid in their blowers when we take them apart.
OP did you buy the car new? I've never heard of a noisy pulley? If anything goes bad on the supercharger it would be bearings or isolator. Or maybe a tensioner/idler pulley could have gone bad which wouldn't require them to remove the blower.
Juiced1 is offline   Reply With Quote
Old 04-18-2020, 01:41 PM   #14
Alain
Alain's Avatar
Subscribed
2018 ZL1 1LE/Red hot
