![]() ![]() Drives: 2018 Redline Edition 2SS Join Date: Dec 2014
Mishimoto catch can and centri supercharger
Hey guys I have an ECS Paxton kit on my SS along with a Mishimoto catch can...I've had it for a year now and it just dawned on me....there's probably boost going into the catch can right? Is this OK? I'm not interested in getting another can so am I OK or am I flirting with disaster? Should I or could I put an inline check valve in? I tried doing some research but I'm a little confused.
Thanks
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD. |
Owning SSes for 50 Years
I just posted a similar question concerning catch cans under boost. I have no clue of how to route the catch can hoses to the new Supercharger. I'm doing an Edelbrock eForce install. I hope someone can chime in with some good advice.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
I would assume in a roots blower the can wouldn't see pressure like a centrifugal would but I could be wrong
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
yeah if it's a PD type blower you can use the traditional style Catch can but a Centri really needs a vented catch can and a check valve so that boost doesn't enter the can and push all the oil out. MightyMouse Wild CC's are great.
Is there anything I can do with the current can that I have? ECS v didn't seem as if it was a big deal when they installed my blower last year.
#6 | |
Yeah a lot of shops probably don't think about it but I bet they wouldn't run a closed CC on their own car. So what you could do is pick up a one way check valve to prevent the boosted air from entering your MM catch can and then I would highly recommend a Metco Valve Cover Breather to deal with the crankcase venting. This will replace your oil filler cap https://www.jegs.com/i/Metco+Motorsp...0aAiMpEALw_wcB |
#7 |
Thanks... I'll look into it
#8 |
Although I am PD, I still run the Mishi catch can with a Metco valve cover breather. Boost is boost regardless if it's Centri or PD and Ideally you want to be able to vent the excess crank case pressure to atmosphere so it's not pushing on the engine seals.
#9 |
Should I still run the check valve?
If I replace the oil cap with that breather it's not going to set offcheck engine light or have a vacuum leak or anything right?
#10 |
The Metco breather has the check valve built into the breather. Its just a plastic disk that pops up when the engine sees boost to vent, then gets sucked closed under vacuum. Mighty mouse catch can is the same way except they place the breather on top of the catch can instead of at the valve cover. Either way they achieve the same thing.
#11 |
No...I'm trying to keep the mishimoto can I have
#12 |
I know that...
Again, I run the Mishimoto can with the metco valve cover breather that has the check valve built in. It achieves the same thing as the Mighty Mouse is all I am saying. Which means it works fine and no check engine lights.
#13 |
Sorry lol. At work and read that quickly lol
So is boost still entering the catch can?
#14 | |
Also make sure you get the Metco breather that has the check valve. https://jannettyracing.com/products/...2015-camaro-ss
