![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: none :( Join Date: Sep 2009
ATV problem, engine/carburator experts help!!
i took out my ATV that has been sitting for a couple of months now after changing the spark plug. problem is the engine doesnt feel as strong as it used to, i cant drift or do doughnuts on sand anymore. when i push the throttle to 100% the thing slows down rather then speed up.. plus when i filled it up with gas it leaked out of the carburator for a while but then stopped for no apparent reason.
Best thing to do is pull off the carb, take out the low and high speed needles and spray them and the carb liberally with carb cleaner. maybe even soak all the parts in carb cleaner. You will be amazed at all the sediment that comes out of the float bowl.
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Use a strand from a wire brush to clean out any small orifices you can find in the carburetor.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
![]() Drives: 2010 camaro Join Date: May 2009
I agree, sounds like you need to clean the carb
ill open it up and clean it but i dont know what you mean by carb cleaner? can i buy it at a repair shop or where?
cleaned the carburater on the inside with petrol and q-tips and still doing the same thing. any other ideas?
#7 |
Make sure all the small openings and passages are clear, check all lines/pipes coming in and out of carb for blockage, check to see if jets/needles are blocked.
#8 |
camaro blogger
sounds more like a spark issue than a air/fuel problem...
#9 |
![]() ![]() Drives: 2010 Aqua blue 2SS/RS M6 Join Date: Jul 2009
well I know all this new gas with ethanol reeks havoc with small engines with carbs, ours did the same thing afeter letting it sit for a few months, as every one has said we took the carb off soaked in carb cleaner, got new gasket changed spark plug and some fuel line worked fine after. Don't know what else to tell you to do if that doesn't work.
#10 |
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS Join Date: May 2009
Maybe your clutch cable is a bit streched too... letting it slip....
#11 |
very little idea of what happened but its working now
. i think cleaning the carburator did it along with pumping up the tires to full. pumped them up after getting a flat then driving it down a closed highway i noticed its working properly again thanks for the help
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 ABM 2SS/RS M6, 98Z28 M6 Join Date: Jan 2008
Was it setting with ethanol gas in it? If so thats probably the issue.
Always Remember! Rest in Peace Brothers
9/11/2001. And thanks to all those who defend and serve! Ordered 5/23/2009 3400 with TPW of 08/03/09 3800 8/11/2009 Arrived 8/21/2009 2SS/RS/Aqua Blue/Grey Interior |
#13 |
The Krazzy bytch
carb cleaner go to any auto shop should be the same stuff, You know carb cleaner stuff you spray in the older cars with Carbs lol.
Mine does something like that, but after it warms up it dies, when I start it I have to have the choke out then as it warms up you put the choke in, but it will only go half way or it will die. Trying to sell my daughters old one that way I can take mine in the shop. lol. |
| Thread | Thread Starter | Forum | Replies | Last Post |
| GM Bulletin HVAC system reprogram caused window problem | VegasSS | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 6 | 10-09-2009 10:05 AM |
| first problem with Camaro | RobH | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 6 | 10-05-2009 10:17 PM |
| GM Bulletin HVAC system reprogram caused window problem | VegasSS | 5th Gen Camaro SS LS LT General Discussions | 16 | 10-02-2009 03:10 PM |
| pm problem | drivingincamaro | Site Related Announcements / Suggestions / Feedback / Questions | 4 | 06-23-2009 11:20 PM |
| Somewhat Annoying Back Seat Problem! | ZNOLMT | 5th Gen Camaro SS LS LT General Discussions | 5 | 06-21-2009 10:22 AM |
