Old 04-10-2020, 09:45 PM   #1
isiegel3
Drives: Chevrolet Camaro
LGX long-term reliability
Hey all,
I am looking at my first 6th Gen and, coming from a 5th Gen SS, was wondering how everyone has fared long-term with the V6 LGX? Are there any major, common issues with these engines anyone has experienced?
Also, does anyone know if M6s are equipped with AFM?
Thanks!
isiegel3 is offline   Reply With Quote
Old 04-10-2020, 10:01 PM   #2
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
Mine has been great but only 25k miles. Other than the infamous A8 shudder, I have no issues or complaints
HCI2000SS is offline   Reply With Quote
Old 04-11-2020, 12:58 AM   #3
Luckycod4
Drives: 2016 Camaro
Originally Posted by isiegel3 View Post
Hey all,
Thanks!
Mine has been great 50k miles only had thermostat issue so it wasnt that bad. As far as I believe only A8 have afm but I could be wrong.
Luckycod4 is offline   Reply With Quote
Old 04-11-2020, 07:56 PM   #4
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I know someone on either here or one of the facebook groups is over 150k miles with hardly no issues.
I’m at 82k miles and I’ve had the transmission shudder (fixed from one flush) and e thermostat issue which I just unplug the battery and replug (will change the sensor later).
AFM is only on the auto’s
Old 04-11-2020, 08:53 PM   #5
HCI2000SS
HCI2000SS's Avatar
If you can find more info on the guy with 150k I'd really like to see that. I've been really wanting to find high mileage 6th gen V6's, and see how they're holding up
Old 04-11-2020, 09:51 PM   #6
mvp88
mvp88's Avatar
Drives: 16 2LT/RS Hy-Blue/manual/NPP/6PBrem
I'm at 26K with no issues. The manuals don't have AFM
mvp88 is offline   Reply With Quote
Old 04-13-2020, 09:40 AM   #7
maksimmus
Drives: maksimmus
65k miles, need to replace engine timing chain
maksimmus is offline   Reply With Quote
Old 04-15-2020, 02:28 PM   #8
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
28k and had the shudder and the transmission temp sensor replaced but that was it.
ItsChristianInHD is offline   Reply With Quote
Old 04-15-2020, 02:36 PM   #9
BluinSC
Drives: BVM 1SS
GM builds a great 6 cyl. The one in my impala and Lacrosse were shriekers at high RPM. Too bad they are going away.
BluinSC is offline   Reply With Quote
Old 04-15-2020, 11:44 PM   #10
Bumbleboy92
Long hauler
I can’t find the one I remember seeing but this guys probably up there by now, he posted having 100k around November 2019
Old 04-16-2020, 12:06 AM   #11
HCI2000SS
HCI2000SS's Avatar
In this guy's case it looks like just the TB issue, and other issue was his own fault. Based on that info, longevity looks semi promising. Thanks you for posting that
Old 04-16-2020, 01:40 PM   #12
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
only real issue mine has had engine-wise is that the ecu botches reading the temp sensor sometimes on startup, and the way the ecu handles errors for the temp sensor is that it no longer trusts it for a dozen startups ...it doesn't re-check or re-test until then.
Luckily, you just have to clear the code and it will re-test and unless you have an actual thermostat issue, it will read fine and you wont have your coolant fan on full blast all the time anymore.
btw, Manuals have all the mechanics of AFM in the engine, it's just not turned on. The lgx of a manual is exactly the same mechanical engine as the one in the auto.
Only other issue i've had with the car that has been significant is the mylink display died on me. Parts stores wont sell you a new one and will try and force you to goto a dealer, so I had to go to ebay and fix it that way. Costs a couple hundred.
Old 04-16-2020, 02:34 PM   #13
DIYguy
DIYguy's Avatar
Drives: 2017 Camaro 1LT
At around 47k miles, so far only the following-
  • Replaced the throttle body due to excessive gear lash
  • Squeaky uni-belt. Added belt dressing sparingly and keeping an eye on it.
  • Leaking intake manifold seals. Cleaned and re-sealed with a tiny smear of RTV.
I change its oil as soon as the indicator reaches 50%, or effectively about every 4k miles.
I consider that to be cheap insurance and preventative maintenance for the engine.
I also pre-emptively changed the A8's transmission fluid and filter recently even though it did not have the shudder.
Again I consider that to be cheap insurance and PM.
I also run a Range device to prevent the annoying dithering back and forth between V6 to V4 modes.
This should help prevent AFM hardware issues longer-term.
And besides, I bought a V6 Camaro, not a Prius. So...
Time will tell, but so far I am very happy with the LGX.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
DIYguy is offline   Reply With Quote
Old 04-18-2020, 12:31 AM   #14
Quix
Quix's Avatar
Drives: 2016 2LT V6 Garnet Red
I have 38k miles and I've had these issues
  • Passenger-side actuator for the heating system stuck open, needed the whole dash taken apart.
  • Infotainment system screen died entirely and apparently reflashing the firmware brought it back.
  • Transmission temperature sensor gave me an error once, but it never returned after being cleared.
I haven't had the transmission shake issue with my A8. I plan to keep the car for a while so we'll see what's next. Hey, it's been the most reliable American car I've ever bought... as well as the only American car.
Quix is offline   Reply With Quote
lgx, reliability
