Old 04-09-2020, 03:03 PM   #1
gcrusco
Drives: 2018 ZL1 1LE, 2014 ZL1
DRIVESHAFT REPLACEMENT? ALUMINUM OR STOCK?
I ended up tearing the boot of my driveshaft at COTA a few weeks back. Not sure how or what happened, but i am being told there are no boot repair kits for the ZL1 1LE driveshaft. So I might as well upgrade if I am replacing.
The car is strictly used on track for road course. Is the best option Aluminum from driveshaft shop?
https://www.driveshaftshop.com/domes...nsmission-only
Has anyone hear good or bad things about aluminum driveshafts on track? or should I try to find a stock replacement?
gcrusco is offline   Reply With Quote
Old 04-09-2020, 03:07 PM   #2
Techdude99
Techdude99's Avatar
Drives: 2019 Chevy Camaro ZL1 1LE
I have an Aluminium one for my 240SX track car (300 whp) from them and it's awesome. Made the car more responsive.
The ZLE has twice the power, but should be fine if the build quality is the same. I planned on upgrading in a year or two.
Techdude99 is offline   Reply With Quote
Old 04-09-2020, 03:16 PM   #3
gcrusco
I probably should add my car will be around 700 whp when done..
Old 04-09-2020, 03:18 PM   #4
Techdude99
Techdude99's Avatar
You'll be fine. I've seen them on much higher HP cars and never personally knew anyone with an issue.
Old 04-09-2020, 04:16 PM   #5
waterman
waterman's Avatar
Drives: Grandad's C2 L89
For another $500 (if your finances allow), you might consider CF. Not a whole lot of weight savings but if durability is the issue, CF may be a viable route/consideration for you.
2018 ZL1 1LE sw/PDR
Old 04-09-2020, 04:55 PM   #6
gcrusco
I have a CF in the 14 zl1 but heard of CF and heat issues on repeated track abuse.
Old 04-09-2020, 06:05 PM   #7
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
The GForce 3.5" aluminum one is ultra smooth and very nice. Two thumbs up so far on mine.
Old 04-10-2020, 11:13 AM   #8
L78toLT1
L78toLT1's Avatar
This^ very pleased with my Gforce shaft. ~ 10k miles and several track days with no issues. I'm around 730whp so you should be fine.
Baby Blue
Old 04-10-2020, 11:30 AM   #9
Techdude99
Techdude99's Avatar
Do you have the total weight of the GForce with adapters?
Old 04-10-2020, 01:21 PM   #10
HoodCheck
HoodCheck's Avatar
Drives: 2018 ZLE (M6/hyper blue)
I don't have personal experience with them, but when I was looking at driveshafts for my Z/28, I heard a LOT of bad feedback about DSS.
HoodCheck is offline   Reply With Quote
Old 04-10-2020, 01:54 PM   #11
Techdude99
Techdude99's Avatar
The one on my Nissan is 10 years old with about a dozen two day HPDE's. No issues. Can't speak to the Chevy version.
Old 04-10-2020, 02:40 PM   #12
Joshinator99
Moderator
Not off hand, but I did weigh the new GForce vs the stock one and the GForce one was about 7 pounds lighter than the stock SS driveshaft. If you have a ZL1, the difference will be even more.
camaro, driveshaft, zl1, zle
