Vararam
Old 04-08-2020, 07:37 AM   #1
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
Picking a camshaft: TSP, JRE, Comp and Lethal
I am planning my build and looking for some comments from people that are using or have used the cam they are commenting on. See my current bolt-ons in my signature. My plan is to purchase a cam kit so I will be upgrading the rods and springs when I swap the cam. Based upon another thread I am leaving the stock trunions in there.
My build is going to eventually get a supercharger so I want the cam I get now to work well with that down the road. This is a daily driver that will probably never see the track (not one anywhere near me). I want to maintain, if not improve low end power with the cam. I know the S.C. will give me that when I get there, but this car rarely goes above 5000 RPMs so power at the top of the range is wasted on me. I don’t want to battle the clutch when going under 25 mph. I am getting a HP tuner, and I know a lot of that will be on my tune, but I mention it to address the size of the cam question, I want something in the stage 2, or mild stage 3 range as long as I can still drive 25 mph. I am also not as concerned with adding sound, this is a performance upgrade, but in the right power band for me (2500).
Enough qualifying statements. I have been reading a lot of great threads on this forum and I have an idea of what I am looking for, but want to hear what has worked and what was learned from a daily driving perspective. I like the brands mentioned in the title of the post. So looking for comments on DD cam that will work with a SC. What I will need that is not in the typical kit, and anything else you wish you knew before you started.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 04-08-2020, 07:44 AM   #2
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
That is a very broad question. What kind of supercharger?
There is no one cam that does everything. I have a TSP Stage 1 LS3, 225/236 and it is a great DD cam. Makes within about 15 rwhp of larger cams but drives excellent and is a N/A cam. This cam would work better with a Pro-Charger style supercharger. It would work ok with a LSA style too but would not be optimal.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 04-08-2020, 07:56 AM   #3
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
If i were to do it again i would stay under .600 lift for spring life, i'm not looking forward to changing springs every 25k miles. I would call BTR and have them custom grind you a cam but they will want to know what kind of FI you will be running as well as other things. I would recommend trunion upgrade to CHE or btr v2 but that's your decision to make.
That being said my jre rough idle blower cam runs very well i can still cruise at 1600rpm with no bucking. The only time i notice there's a cam is the choppy idle and slow speed parking lot driving, have to use the clutch more. I also have to give her a little more rpm to take off from a stop smoothly. I haven't been to the dyno for the finished running yet though.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 04-08-2020, 09:04 AM   #4
Juiced1
Drives: 2012 2SS CAMARO 45th
There are plenty of options out there for you. My first question is on the supercharger. If you plan on going with a centrifugal then a N/A style cam would probably be best. It'll work great N/A and solid with your blower. If you plan on going with a roots blower a PD blower cam would suit you best. Give us a call and we'll get you set up right.
Juiced1 is offline   Reply With Quote
Old 04-08-2020, 06:07 PM   #5
JLGO
JLGO's Avatar
Drives: 2015 Camaro SS convertible L99
Go with TSP, and a remote tuning from them also.
JLGO is offline   Reply With Quote
Old 04-08-2020, 10:32 PM   #6
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
I gotta say Lethal wins the marketing competition. The name Night Fury makes me want to get it in that alone. Looking at the specs though and some of the comments from those that have it is a bit aggressive for a DD. Not sure how well it matches up with a S.C., anyone have that set up?
Old 04-09-2020, 08:13 AM   #7
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Have PatG https://www.patgtuning.com/ spec a custom cam and then have Cam Motion grind it for you.
Good Luck!
PEACE
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 04-09-2020, 09:49 AM   #8
xc_SS/RS
Drives: 2010 Camaro SS/RS
What’s aggressive to one guy as a DD could seem stock to another. You’ll only know what/where your limit is after you drive a car with a different camshaft in it so don’t focus much on that
Lots of reviews on this site about this cam and I’d say most are positive. Type it into google and check some out
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 04-09-2020, 10:16 AM   #9
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
I want to push the line between as much HP as I can without making it a pain to drive at 25 mph or in a parking lot. The SC down the road will really ramp things up, but in the meantime I am trying to build an engine that is fast and will accept the SC.
I went to PatG website, am I right that it will cost $40 for advice? I like the idea of getting a custom made cam, but I don't want to pay $40 to find out that a comp cam or TSP makes one with similar specs without the custom price.
Old 04-10-2020, 09:53 AM   #10
Nb1081
Drives: 10 2ss/rs
Tsp, gpi, cam motion, ljms,btr in no particular order
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 04-10-2020, 02:46 PM   #11
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Again, most will want to know what SC. You cant "custom" anything until you have all the facts.
On that note.....if you want drive-ability.... why not keep stock cam?
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 04-10-2020, 04:29 PM   #12
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
90% sure it will be a Whipple. I am looking at a cam for the added hp.
Old 04-10-2020, 06:45 PM   #13
2011SSCT
2011SSCT's Avatar
Drives: 2011 Camaro 2SS/RS
I just had JRE's blower cam installed in my car knowing I'd be doing the Whipple in a couple months. Yes, spending all that cash at once would have had me in divorce court....lol. I'm an auto so I obviously had the L99 to LS3 conversion too. I thought I'd be trading some drivability for HP, but my car runs and drives better than it did before. I know we're comparing apples to oranges because I'm an auto, but the JRE cam produced amazing numbers for an auto.
L99 to LS3, Whipple 2.9 Blower with 3.750 pulley, ID1050x injectors, JRE Rough Idle Blower Cam, BTR Bronze Bushing Trunnion Kit , JRE/BTR .660 Springs, BTR Pushrods, Melling High Volume Oil Pump, ZL1 Fuel Pump, JRE FPCM, JMS BAP, JRE 90MM Ported Throttle Body Circle D 3200 Stall Converter, Ceramic Coated Kooks Long Tubes, Kooks Full Exhaust with Hi Flow Cats, Cold Air Inductions Intake With JRE Scoop, JRE Built Rear Differential with Billet Caps, 3:91 Gears and Eaton TrueTrac Posi, JRE Dyno Tune, Moroso Wires, Moroso Catch Can, Factory Reproductions Gloss Black ZL1 Wheels. 659WHP/566TQ
2011SSCT is offline   Reply With Quote
Old 04-10-2020, 07:41 PM   #14
ABM Camaro
ABM Camaro's Avatar
Drives: 2013 ZL1 A6 Camaro
Most of the companies listed carry comp cams ground for their shop with minimal difference between each of them.
Just reach out for Comp Cams and have a truely custom grind cam for you. They also have plenty off the shelf cams they ship to shops with cool names
https://www.compcams.com/cam-recommendation-form
2013 ZL1 Camaro A6. ARH Headers, K&N intake, Tuned by Tampa Tuning
2014
V6 Camaro bolt ons and E85
ABM Camaro is offline   Reply With Quote
