Old 04-06-2020, 11:14 PM   #1
Waleedriazz
Drives: 2018 1LT Camaro 2.0 I-4
How to remove the stock cold air intake?
Hey guys,
I hope you are all doing well.
I was trying to switch the stock intake in my Camaro 2018 (2.0) with the Injen Evo 7300 CAI but unfortunately, I am stuck at the PCV hose (crankcase) from the intake tube. I don't know how to remove it. There was no tool in the box to be used for the removal.
The 2016/17 models had a different clip. I have attached pictures for reference.
Awaiting the help from y'all!
Waleedriazz is offline   Reply With Quote
Old 04-07-2020, 05:49 AM   #2
18i4m6
18i4m6's Avatar
Drives: 2018 I4 M6
It's a common problem, there is a tool that will take it off, don't try to force it. It referenced in old CAI threads on here, I don't know where off the top of my head tho. Basically it slides under and releases the clips.
Black 2018 Camaro LS M6
Tinted/blackout paint everywhere/debadged
Catted Mishimoto downpipe
Mishimoto CAI
MBRP V6 axleback exhaust
Jacfab/BNR Boostolator
Racechip RS
Firestone Firehawk Indy 500's
Onstar tracking removal - pending
18i4m6 is offline   Reply With Quote
Old 04-07-2020, 08:26 AM   #3
Davescamaro
Drives: Chevy camaro
I removed mine with a set of pick tools (the 90 degree ones) to slide both counterclockwise simultaneously and gently push up. If it does break on yours, your local chevy dealership may not have it in stock. I bought a spare just in case. Realized the K&N intake does not require removal after jumping the gun on the instructions (dumb me).
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears.
Davescamaro is offline   Reply With Quote
Old 04-07-2020, 09:02 AM   #4
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
get a set of plastic hose removers from the parts store. will have to grind the (TOOL) plastic neck down to accommodate the clearance. it looks like this connector uses 2 legs.
either way you want to slide a shim up the connector head to disengage the tabs.
https://www.autozone.com/test-scan-a...iece/13603_0_0
NFG M6 2T
Mishimoto Hot side pie | ZZP Catted DP | KN Drop in | Borla - Sport Tour | Apex Arc 8 - square | Wookster Tuning+ | Flex Fuel
Last PB
4.8, 13.2@106
wookwook is offline   Reply With Quote
Old 04-07-2020, 03:17 PM   #5
lcd550
lcd550's Avatar
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert
Check out this link, see post #13.
I used that and it worked
https://www.camaro6.com/forums/showt...&highlight=PCV
lcd550 is offline   Reply With Quote
Old 04-07-2020, 07:24 PM   #6
Waleedriazz
Thanks, guys.
But I live in Canada and it's not available in the nearby stores.
Online is not an option thanks to covid since sites like Amazon are taking a month to deliver (EVEN ON PRIME).
Any alternative?
Old 04-07-2020, 07:41 PM   #7
lcd550
lcd550's Avatar
Originally Posted by Waleedriazz View Post
Thanks, guys.
Any alternative?
Did you check ordering the tool thru Home Depot?
https://www.homedepot.com/p/Lisle-An...9400/306763669
Old 04-07-2020, 07:57 PM   #8
lcd550
lcd550's Avatar
Another option is using a pick tool. Check out this set from Princess Auto
https://www.princessauto.com/en/deta...et/A-p8572703e
Check out Post #5 on this thread:
https://www.camaro6.com/forums/showt...&highlight=pcv
Old 04-07-2020, 10:09 PM   #9
Wierd Harold
Drives: 2017 2lt rs
Napa,parts source,uap,should have the tool ,I think you can get away with the cheap plastic ones(fuel line disconnect tool
Wierd Harold is offline   Reply With Quote
Old 04-09-2020, 03:34 AM   #10
Waleedriazz
The HomeDepot only has it in US, and the Post#5 refers to the old clip. I'll found one at Canadian tire. Will order tomorrow. Hopefully that should work. If not, will try my luck with these sites.
Thanks guys!
Old 04-11-2020, 04:42 AM   #11
Waleedriazz
Thank you, everyone.
The metallic disconnect tool is simply not enough as it does not fit well. Used it along with the pick tool set (which was too tiny to be used exclusively). and IT WORKEDD!
Old 04-11-2020, 05:43 AM   #12
18i4m6
18i4m6's Avatar
Drives: 2018 I4 M6
Congrats, you'll love it. I had a brief light with mine but it went away and has not come back.
Mishimoto CAI
Racechip RS
Old 04-11-2020, 03:12 PM   #13
lcd550
lcd550's Avatar
Congratulations...mission accomplished!!!
Enjoy!
cai, intake, ltg, removal, replace
