Old 04-06-2020, 08:59 AM   #1
Jeff.N
Drives: 2017 Camaro 1LE
Oil Cooler Leak
Good Morning!
Last week while changing my oil in the 1LE, I found some burnt oil residue on the oil pan. Found some bolts on the oil pan that were loose and had oil residue. Brought the car into the dealership today and they are fixing it under warranty. They also informed me that the oil cooler is also leaking and they want to replace it ($900), but it is NOT covered under warranty which I found strange. I told them to proceed with the oil pan but I will take care of the cooler.
Has anyone dealt with a bad oil cooler before, or had one go bad? It doesn't look like its hard to change, 4 bolts, a couple lines and a gasket.
Thanks,
Jeff
Jeff.N is offline   Reply With Quote
Old 04-06-2020, 09:54 AM   #2
RolltideSS
RolltideSS's Avatar
Drives: 2018 SS 1LE
Are you out of the 3 yr /36,000 Mile warrant? I don’t see why the oil cooler wouldn’t be covered unless they are saying it’s not part of the driveline warranty
RolltideSS is offline   Reply With Quote
Old 04-06-2020, 09:55 AM   #3
Jeff.N
Yeah I only have powertrain warranty now.
Old 04-06-2020, 10:02 AM   #4
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Yeah, I've seen a few people on here have issues with the oil pan. That's odd that they're trying to say the oil cooler isn't part of powertrain when the oil pan is...might want to check with another dealer on that one.
I've not heard anything on the oil cooler so I'd wipe it down and make sure it's actually leaking before swapping (in case it's just stuff leaking from the oil pan that ran down and dealer thought it was oil cooler). But, if you do determine that it's actually leaking, you're right it's pretty straightforward. 4 bolts, 2 quick disconnects, and a gasket. Steps are:
  1. Drain oil
  2. Drain coolant
  3. Remove 4 oil cooler bolts
  4. Remove gasket and clean gasket surface
  5. New quick disconnect fittings must be used any time hose is disconnected. If not using a new oil cooler with these already installed, you'll need a pair of new connectors and seals. These are torqued to 34 Nm (25 lb-ft).
  6. Install oil cooler using a new gasket. Bolts are torqued to 10 Nm (89 in-lb).
  7. Connect hoses and fill oil/coolant
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 04-06-2020, 10:03 AM   #5
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I would try just torquing the oil cooler bolts, before I went through tearing it apart. You might find them loose.
Old 04-06-2020, 10:09 AM   #6
Alpha1BC
Alpha1BC's Avatar
Good point. If it's leaking from where it mounts to the engine that's definitely what I'd check first before opening the system up.
2017 SS 1LE.
Old 04-06-2020, 10:26 AM   #7
Jeff.N
Will do thanks!
