Old 04-05-2020, 06:22 AM   #1
Devstrike
Devstrike's Avatar
Drives: 2020 Camaro LT1
2020 LT1 Camaro performance Timer question
So I have been searching for a couple of hours on these forums and with google and I still have not found how to set up a 0-60 setting on the performance timer with my LT1. I have seen a few videos of it showing up dashboards for other LT1 owners or 1LT or 2LT owners but none that show you how they did it. No replies back from the uploaders either. Any other LT1, 1LT or 2LT owners mind helping me out? It seems to work differently than the SS and up ones.
EDIT: My Manual said to hold the > arrow with the performance timer window up to access the menu but after holding it down for a while nothing happens.
EDIT: In the picture I uploaded I also don't seem to have the right arrow option that others do and where my manual says there should be on on the base cluster.
Devstrike is offline   Reply With Quote
Old 04-05-2020, 06:49 AM   #2
GOMD
GOMD's Avatar
Drives: 2017 Camaro 1SS, 2023 Sierra
As far as I can tell, you won’t have the performance menu on the smaller cluster. It seems to be only available on the larger all digital cluster.
GOMD is offline   Reply With Quote
Old 04-05-2020, 06:52 AM   #3
Devstrike
Devstrike's Avatar
This guy has it on his LT1 with the same cluster as mine. Which is why I am confused on why mine isn't working like his.
Old 04-05-2020, 07:01 AM   #4
GOMD
GOMD's Avatar
That’s odd. Have you checked all the different menus? Including the couple hidden menus at the bottom when scrolling? Maybe you have to activate it.
I really do not know, have not been in a 2020 LT1. Sorry if I am not helping.
Old 04-05-2020, 07:04 AM   #5
Devstrike
Devstrike's Avatar
I believe I did however this car is still very new to me so I am not ruling out that I missed something. I am at home now though so I will have to mess with it when I am back in the car next.
Old 04-05-2020, 07:07 AM   #6
GOMD
GOMD's Avatar
I checked the owners manual online, but it is not very specific. Play around with all the menus, best of luck finding it.
Old 04-05-2020, 07:16 AM   #7
GOMD
GOMD's Avatar
This is for the bigger screen, but can you try something similar on yours?
Maybe it’s de activated from factory.
https://youtu.be/wRB6Ls0A3es
Old 04-05-2020, 08:11 AM   #8
mrgoodbytes
mrgoodbytes's Avatar
Drives: '18 2SS/EU (+Recaros) M6 Red Hot
The 0-60 timer was hidden on my SS when I got it.
I had to enable it in the performance menu, exactly like the video in the post by GOMD suggested.
mrgoodbytes is offline   Reply With Quote
Old 04-05-2020, 10:04 AM   #9
Fraxum
Fraxum's Avatar
It is there, I just checked all 3 performance popups.
  1. Use the up/down toggle on the lower right of the steering wheel to find "Info Pages".
  2. Use the right arrow to enter the list of infos.
  3. Toggle up or down until the page you want is selected
  4. Use the right and left arrows to select or deselect any page.
I turned on all 3.
COOL! I have the Bigger screen but that does not make a difference (I Think)
As far as I can tell so far the LT1 Has these things missing all 1SSes Have:
  • Track cooling
  • Rear Brembos
  • Brake ducts (To DIY)
  • Skinnier wheels
  • All season tires instead of summer tres (A winter setup!)
  • Tow Hook receiver
  • No MRC option
  • Less weight
  • And you can add Bose to the LT1
OP Good luck getting traction with the 245 all seasons. In cooler weather first gear is useless.
Old 04-05-2020, 04:41 PM   #10
Devstrike
Devstrike's Avatar
Thanks for all the help going to go out and see if I can get it working in the menus. I am not exactly going to do a pull yet since the manual has some break in restrictions until 1500 miles but I wanted to see how it did under normal accelerations. I am weird like that. lol
Old 04-05-2020, 04:43 PM   #11
Devstrike
Devstrike's Avatar
  • Track cooling
  • Rear Brembos
  • Skinnier wheels
  • Tow Hook receiver
  • No MRC option
  • Less weight
My brochure book that the dealer gave me said the LT1 had the engine cooler is that not correct? The book said the trans and diff cooler were SS only though.
Old 04-05-2020, 05:35 PM   #12
Devstrike
Devstrike's Avatar
Update: Found them and I had a lot of goodies G force option Lap time and 0-60 timer. I had to go to options scroll down to the blank info page hit right arrow and then select pages and check off those 3. Thanks again for the help guys.
Old 04-05-2020, 06:37 PM   #13
RWT
RWT's Avatar
Drives: 2020 Camaro RS
Wow, I just went out to my RS and did this only to discover I too have these options.
Very cool
RWT
2020 Camaro RS, V6, 6MT, Satin Steel
2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray
2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic
RWT is offline   Reply With Quote
Old 04-05-2020, 07:35 PM   #14
caSStro18
Drives: 2018 Camaro SS
I think think he’s talking about the high capacity cooling. The SS models have two additional radiators on both sides of the main radiator for additional cooling capacity. I’m pretty sure the LT1’s don’t have this. But I’ve never looked at an LT1 to confirm this.
caSStro18 is offline   Reply With Quote
