Old 04-04-2020, 04:57 PM   #1
Tha_Infamous_E
Drives: 2017 Camaro SS
Air Lift Suspension
Was wondering if there's a product somewhere for only front suspensions to allow the car to lift couple inches higher than normal just for clearance over driveways and other things alike?
I don't want to limit performance once lowered back to normal height, just a quick lift for clearance then lowering back to normal.
Tha_Infamous_E is offline   Reply With Quote
Old 04-04-2020, 10:44 PM   #2
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
Talking about being on stock suspension? Nope. But there’s multiple coilover lift options
RobertAvitia is offline   Reply With Quote
Old 04-05-2020, 10:43 AM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Best I can think of is Air Lift Performance for something you can control from the seat of the car. I'm sure there are other companies out there that do something similar, but they're the ones I'm most familiar with.
If you don't mind slipping a jack under the front end to install/remove stuff on the springs to get a quick lift you might be able to use the shipping spacers that come with the 1LE, PN 84102427. They raise the front end by about an inch or two for clearing the ramps on car trailers and/or tow trucks.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
