![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Suspension GURUS please ADVISE!!!
I recently purchased a 2019 SS WITHOUT MRC and while I HATED the ride on my ZL1 1LE and I got rid of it and got this car; I would like to set up this SS to handle as well as possible WITHOUT riding like a DUMP TRUCK since this is a daily driver.
I will be getting APEX wheels 19 x 10.5 SQUARE set up with Michelin Pilot Sport 4S 305 30 19's all the way around. I ALSO have purchased the UMI/PFADT lowering springs. I also am replacing the STOCK brake system with the complete system off a ZL1 NOW, with the above options as a base , what would you add to OPTIMIZE handling. As a side note, I DID look into ADDING MRC after the fact, but it is cost prohibitive.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 04-04-2020 at 12:53 PM. |
![]() Drives: 2019 SS Join Date: Apr 2020
Not lowering it is the first thing to making a better ride.
Well I should have mentioned. I have NO problem with a firmer ride than stock but the ZL1 ILE set up is WAY too uncompromising when it comes to ride quality. The REGULAR Zl1 with MRC is IMO perfect compromise but unfortunately VERY few SS have mag ride option because I tried to find one but had no luck. I wanted the A10 so that's why I ended up with a 2019.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 04-04-2020 at 02:06 PM. |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
I'm not seeing any UMI/PFADT lowering springs for a 6th gen Camaro with a quick google search to check specs, but in general I'd suggest avoiding changing just springs and not dampers. Lowering springs typically increase spring rate which would normally require damper changes to match if you want to be "optimized." If that's your main goal, I'd suggest returning the lowering springs and looking into coil-overs and adjustable sway bars if you're not afraid of setting up suspension on your own, or push the easy button and get GM's Lowering Suspension Upgrade System (PN 84225254) and Sway Bar Upgrade System (PN 84242386). With the GM stuff you get new springs and dampers with the lowering system, and stiffer sway bars and front handling links to stiffen stuff up a bit more without completely killing the ride you have with the stock setup.
Or, to play the long game, maybe even sit back and wait for this to get all your suspension upgrades and more: https://gmauthority.com/blog/2020/04...ne-key-update/
2017 SS 1LE.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
![]() Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR Join Date: Aug 2018
He wanted the A10.
OP, you could contact Jeff at ProParts USA about dampers. Jeff has made Koni dampers for his SS non MRC car.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track |
#7 | |
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#8 |
Thank you Al Oppenheiser!
+1 on the GM kit.
Al O's team designed one of the world's best (if not THE world's best) suspensions. It ain't broke ... so.... |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
powell yyz springs and his new bilsteins ftw and oem 1le or zl1 swaybars
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
SS 1LE A10 available for 2021...
