Old 03-30-2020, 07:24 PM   #1
ericedelman
ericedelman's Avatar
Drives: 2020 ZL1
Differential Plug Gasket or Replace Plugs?
Is there a replacement gasket for the differential fill plugs, or are the plugs single use only?
I used two GM 55573646 plugs as replacements when I changed the gear oil this past weekend. The plugs are around $4 a piece from the dealer, which I suppose isn’t that bad considering I pumped in $50 worth of GM gear oil.
2020 ZL1
ericedelman is offline   Reply With Quote
Old 03-30-2020, 07:54 PM   #2
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
My very first diff change I reused the OEM plugs "as is", then the following changes I've replaced the crushed OEM gaskets only, with something like these without issues...
(10 gaskets for about $10 bucks)
https://www.dormanproducts.com/p-695-097-139.aspx
driven2exceSS is offline   Reply With Quote
Old 04-02-2020, 04:04 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Originally Posted by Kasey00 View Post
However, in some very rare cases, excessive pressure inside the rear end housing can also lead to pushing the gasket out which can also create a leak. Under most circumstances, a slow leaking differential won't cause any problems with driving. However, since the oil supply has no way of being replenished without physically adding it to the differential.
excessive pressure in the rear? You realize there is a vent on top of the differential to prevent this "situation".
