Old 03-30-2020, 07:40 AM   #1
Brandonc_06
Drives: Chevy Camaro 2017
Tsp Stage 3 cam
Im down south in texas and I have e85, headers, cai and also getting a stage 3 cam from texas speed. What gains should I expect? Im at 450rwhp
Brandonc_06 is offline   Reply With Quote
Old 03-30-2020, 07:46 AM   #2
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
If you don't plan on doing heads with the cam, get a smaller cam
That1guy_tim is offline   Reply With Quote
Old 03-30-2020, 07:47 AM   #3
That1guy_tim
Drives: Camaro 1ss
Read this
https://www.camaro6.com/forums/showthread.php?t=572275
Old 03-30-2020, 08:04 AM   #4
That1guy_tim
Drives: Camaro 1ss
that 5.6 is theoretical due to where the elevation that man is at.. it's still a LT1 engine.
Old 03-30-2020, 08:59 AM   #5
Umbriel
Drives: 2016 Camaro SS
Originally Posted by Brandonc_06 View Post
Thats for a 5.6L c7
No Corvette comes with a 5.6 liter engine, it is a 6.2 LT1 just like in the Camaro.
Umbriel is offline   Reply With Quote
Old 03-30-2020, 09:27 AM   #6
Snowblind
Snowblind's Avatar
Call Texas Speed. Tell them your goals and mods, they will help you pick the right cam for your car. Don't be like that guy in the link and pick a big cam without the proper complimenting parts.
Old 03-30-2020, 02:29 PM   #7
Nabush
Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE
The only complimentary part I was missing was the ported heads.
AFE CAI
87mm Katech Ported TB
Ported MSD Manifold
TSP Stage 3 cam /PRC Dual springs/DOD delete/C5R timing chain/Trunion upgrade etc
ARH LT headers
When I asked everywhere before buying stuff all people said heads were a waste of money, only good for 15 WHP for $1200
Unlike all of you guys I did the job myself (cam AND tuning) so I learned a lot , though I already tuned myself the car when I was FBO, car making 458WHP/420WTQ on a Mustang dyno, so not bad at all (dynojets bump torque readings a lot). Guys showing 530whp at 6000rpm and 480 WTQ is BS from dynojet dynos, especially on Auto cars which read a lot lower. Put them on a Mustang dyno and you'll see 5-10% less.
530WHP is achievable on a Mustang dyno with this config but at 6500-6800 rpm with an MSD, not stock IM as I see in another thread
I ordered yesterday ported heads from TSP, I'll see what it does, but part of my torque problem in the 3300-4000 range lies in the MSD manifold since putting OEM manifold decrease by 50% the observed torque loss.
Nabush is offline   Reply With Quote
Old 03-30-2020, 08:05 PM   #8
oldman
Drives: SS 6 speed of course
The stock head flows less at lifts above .550. So what is the point of a rapid profile cam and .640 up lift? The cam is large probably work better with 12.25 cr and E50 or 93. A smaller cam with less lift will produce the same hp from 6000 up, but WAY more torque midrange.
Also, there is NOTHiNG in the valve train that can take the cam IMO. So welcome to pushrods, trunion, c5r chain,jhoneson lifter, pushrod length checker, springs shims, spring height checker, springs (change every 20k miles), valve guide wear, valve / seat refacing, have the studs crack into the intake ports on ported heads, hope you don’t have valve bounce or the stock hollow intake head will fall into the chamber, better lock the cam gear. But what do I know?
Old 03-30-2020, 08:17 PM   #9
oldman
Originally Posted by 6spdhyperblue View Post
That’s peak. Gotta think avg hp too if you are looking to run faster. Why give up better drivability
Or dependability. A .600 lift cam motion cam could have double the longevity on way less expensive parts. IMO a Cam Motion cam .600 lift and all the $$$ parts is the only combination that can offer 100k miles, I’ll let you all know if it does not.
Old 03-30-2020, 10:44 PM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I agree with has been previously mentioned. I would rather run a lower lift cam and give up a few HP in exchange for better reliability and longer spring life with less exotic components. Imo stock rocker arms, LS7 lifters, and dual springs don't belong in a combo with a .640 lift cam. Most of these vendors are selling cam kits that might last 20k miles before something(s) will need repaired or replaced...lifter, valve spring, valve guide.
Stock rockers and LS7 lifter combo imo should stay under .600 lift with a mild ramp lobe. Cam motion will put together a good reliable package...shoot them a call.
Old 03-31-2020, 06:57 AM   #11
6spdhyperblue
Drives: 2SS 1LE
I am guessing this is on the a8?
Old 03-31-2020, 01:41 PM   #12
Brandonc_06
M6
Old 04-01-2020, 12:36 AM   #13
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
AFE CAI
Ported MSD Manifold
ARH LT headers
Dynojets definately read higher, but I wouldn't say they bump anything. A lot of reputable sources would say the dyno jet is the more repeatable and less manipulated platform.
I don't know anyone, at least on this forum or fb groups, claiming 530hp out of a fbo car. Except Prays record m6 car which made 530 but also ran a 10.3 backing up that hp number... and that was definately a max effort fbo car, shy or a cam or heads.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 04-01-2020, 11:01 AM   #14
Nabush
You sure can manipulate numbers on a Mustang dyno...
From what I saw, Mustang dynos are very repeatable, several pulls with same tune were showing exactly same numbers...
When I was talking 530WHP at 6000 rpm this was with cam and heads on an A8, without MSD and TB. No way. 490-500whp max.
