Old 03-28-2020, 05:43 PM   #1
s3rics213
1khp_1le
Drives: 2019 1LE/ss 2014 ss/rs summit white
Lt1 swapped lt4 hpfp issue
Update: Harness 12689504 will be a direct swap for harnesses for anyone with a 2019 trying to upgrade the hpfp to the lt4 pump.
Original:
Everyone that’s done the lt4 hpfp upgrade where the connectors the same. My connectors don’t match up. Lt4 pump 12694529 and my old pumps numbers 12697967. First pics new pump second is old.
Anyone have any idea thought these are plug and play.
2019 camaro ss
Injectors already swapped and d1x with 10 psi
s3rics213 is offline   Reply With Quote
Old 03-30-2020, 11:47 AM   #2
TJay74
My guess is that new "LT4 / HPFP" is the wrong pump. Have you cross checked the part # on it?
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 03-30-2020, 12:48 PM   #3
s3rics213
1khp_1le
Yes the lt4 pump number hasn’t changed from 18 to 19-20 zl1. It’s the lt1 on the 19 that changed from the electrical. Even the dealership shows that the pumps completely changed on the lt1 and the lt4 stayed the same.
Old 03-31-2020, 10:27 PM   #4
New_image
Drives: 2019 Camaro 1LE
I would like to hear more on this. My pump and injectors are on the shelf. Waiting on my supercharger to show up before I start the install.
New_image is offline   Reply With Quote
Old 04-01-2020, 01:20 AM   #5
s3rics213
1khp_1le
I ordered a new harness and I can supply pn later just won’t have access to the shop and car till Friday to see if it works.
Update:
Looks like harness 12689504 will be a direct swap for harnesses for anyone with a 2019 trying to upgrade the hpfp to the lt4 pump. Will be swapping on Friday to verify.
Old 04-01-2020, 04:38 PM   #6
New_image
Update:
Old 04-02-2020, 01:18 PM   #7
ADM PERFORMANCE
Drives: Anything I want
Swapping harness is the correct way to do this
We use the lt4 harness all the time from the camaro zl1 and corvette.
ADM PERFORMANCE is offline   Reply With Quote
Old 04-02-2020, 09:54 PM   #8
s3rics213
1khp_1le
Old 04-26-2021, 04:20 AM   #9
Airstang93
Drives: 2013 Camaro SS 1le
Update:
Did you order direct from GM?
Airstang93 is offline   Reply With Quote
Old 04-26-2021, 01:52 PM   #10
MrRuss
MrRuss's Avatar
I am also upgrading to LT4 fueling on my 2016 SS in preparation for an LT4 SC install. As far as I know I will need injectors, both fuel pumps and a voltage booster but having trouble finding the exact part numbers. Rock auto has half a dozen injectors for a 2017 ZL1 and I'm not sure which one is correct. Any help would be much appreciated. I also know I need to change my flex fuel to ZL1.
Also any other parts needed? How about a good install write up?
Mr Russ
Tim "the tool man" Taylor is my hero
My Garage:
'16 Chevrolet Camaro 2SS, Summit White, Adrenaline Red
-- Rotofab CAI, Soler TB, 1 7/8 coated LT's, Full 3" mids, 3" Stainless Works NPP mufflers, Flex Fuel, E85/91 tuned
'20 Honda Oddysey Elite 25th Anniversary Edition
--wifes car, she said "No more SUV's" after the 2 CX-9's totaled
MrRuss is offline   Reply With Quote
Old 04-26-2021, 03:01 PM   #11
Puddin
Why would you need to change your flex fuel sensor?
Old 04-26-2021, 03:36 PM   #12
MrRuss
MrRuss's Avatar
It's my understanding that the flex fuel kit is different for the LT4 vs. LT1
Mr Russ
My Garage:
Old 04-26-2021, 03:38 PM   #13
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
The top pic is exactly what came off my 2016 SS.. It was a direct swap for my LT4 pump off my 17 ZL1... I gave my wife's SS my LT4 pump and injectors I took the SS pump and injectors for my zl1. about 4 mos. ago one of my SS injectors off her car died so I just put all new Lt4 injectors and lt4 pump back.
LT4 pump I used
GM 12688607
AC/Delco HPM1036
Old 04-26-2021, 03:40 PM   #14
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Not sure about flex fuel kit but definitely the AUX pump kit on a ss and zl1 are different most likely from the map sensor.
