Old 03-25-2020, 12:28 PM   #1
BPSS
Drives: Camaro 2SS 2018
First dealer service (wrong filter)
Hello all
Just the got the first service done at the dealer/workshop where i bought the car last year.
Normally i would do it myself, but for me to still have the guarantee on the car, i was “forced” to use the dealer´s workshop :(
I askede them if they had the original filter, yes no problem they Said.
I even had a PF64 in the trunk for them to use.
But they had it all they said, the service got done, i drove home and found this under my car
They have used a PF48E !!!
My question is, am i Safe with this filter or should i ask them to replace it with a PF64.
BPSS is offline   Reply With Quote
Old 03-25-2020, 12:48 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
have them replace it with correct one
Old 03-25-2020, 12:49 PM   #3
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
This is what I found on the InterWebs...
Important: The PF64 and PF63, which is commonly confused by many in the automobile service industry as an ACDelco® PF48 and/or PF48E , because both oil filters have the same appearance and oil can size. However these oil filters are not the same and have different internal bypass valve opening pressure specifications (PF48/PF48E = 15 PSI (100 kPa), PF64/PF63E = 22 PSI (150 kPa).
https://www.corvetteforum.com/forums...d-of-pf64.html
I`m Batman is offline   Reply With Quote
Old 03-25-2020, 12:54 PM   #4
2017Darkness
2017Darkness's Avatar
Drives: 2019 2SS 1LE
The internal bypass valve is the only difference. The 64 has a 22psi bypass where the 48 has 15. You should be fine, but some people think the lighter bypass lets more junk bypass the filter...The 48 has been used on Corvettes for quite some time.
2017Darkness is offline   Reply With Quote
Old 03-25-2020, 01:42 PM   #5
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Those had a different lube system though. GM has posted bulletins to ensure the correct oil filter gets used in the field - I personally would follow their recommendation.
OP, That is really careless that the dealer got it wrong! I'd be hesitant to have them do any other work on it.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 03-25-2020, 01:44 PM   #6
ctrlz
I agree.
For most of us who take care of our cars, the bypass valve never opens.
The rating of that valve is the pressure differential across the filter media (called "PSID" by manufacturers).
Pressure across the filter is related to:
1) Oil temp/viscosity
2) flow rate
3) the extent to which the filter media is clogged.
Here is some data for a Purolator filter:
https://www.bobistheoilguy.com/forum..._vs._PSID_Data
As someone else said, "If you are cold starting your car in Alaska AND immediately high-revving the engine AND your filter is very old you MAY get the bypass valve to open."
Old 03-25-2020, 02:09 PM   #7
95 imp
Dumb Ass Deluxe
I'd get the correct one if it were me. The bypass, which *should* never open if you change your filter correctly, could still let unfiltered oil thru if it does open.
Old 03-25-2020, 06:41 PM   #8
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
no need to worry. bypass value pressure only works when the filter material is so clogged it need to bypass the filter. If you are changing your oil and filter on schedule your filter will never use the bypass valve.
dpevans is offline   Reply With Quote
Old 03-25-2020, 10:25 PM   #9
Just Cruzin
Just Cruzin's Avatar
Drives: 2017 SS 50th Anniv & 1969 SS350
Whenever I go to the chevy parts counter to get my oil filter they always advise the computer recommends the PF48 but I know to get the PF64 so that's what I get. I think GM might be confusing the dealerships with two different oil filter recommendations.
Just Cruzin is offline   Reply With Quote
Old 03-26-2020, 12:23 AM   #10
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
GM service bulletin regarding oil filters for the LT1 and other GM engines.
I agree the chances of the bypass opening, even at the PF48's low pressure setting, is slim.
I agree that it is more troubling that the dealership installed the wrong filter.
File Type: pdf Oil Filter Service Bulletin #17-NA-157.pdf (161.3 KB, 241 views)
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 03-26-2020, 04:55 AM   #11
URBAN LEGEND
URBAN LEGEND's Avatar
I do my own now. It’s so easy on this car. I don’t trust dealerships.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 03-26-2020, 05:05 AM   #12
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
you dont have to use the dealer to keep your warranty. they say you should keep your receipts for parts but unless your oil analysis comes back with junk oil you will be fine. just change the filter yourself. no need to take your car to a tech thats pissed off that he has to redo it.
Old 03-26-2020, 07:45 AM   #13
vtirocz
vtirocz's Avatar
Stuff like this happening is the reason I didn’t use my two free oil changes. It wasn’t worth it to me.
Old 03-26-2020, 08:22 AM   #14
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Well I see it that if something goes wrong with your Camaro the dealership can be held responsible since they installed the wrong filter. I would though drop by and talk to the Service Advisor and express your concerns!��
