Old 03-24-2020, 06:07 PM   #1
Junkyardspecial
Junkyardspecial's Avatar
Drives: 2018 ZL1 1LE
Failing steering rack.
Going to bring my car in for some warranty work. After a recent trip to tail of the dragon my front end alignment worked itself out.
A loud noise at low speed and from the front right wheel materialized. Also when jacked the the air, when turning the steering wheel with the car on the front wheels violently shake, almost like a jeep death wobble.
Im guessing a damper or the steering rack failed. Has anyone else dealt with this before?
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial
Will buy your GoodYear Supercar 3R Take offs!
Junkyardspecial is offline   Reply With Quote
Old 03-24-2020, 06:33 PM   #2
FoundNemo
Drives: 2019 ZL1
FYI, ZLE's have cooling vent near the steering rack (electric rack) to keep it cool in heavy track use. Not sure the dragon is enough to do it but maybe. There is a post somewhere about it recently.
FoundNemo is offline   Reply With Quote
Old 03-24-2020, 07:06 PM   #3
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
You hit any big potholes by chance? I’ve had 2 steering racks fail due to heavy hits in potholes. I could not see them. Obviously not on my ZLE but I’ve had it happen so if you did hammer a hole there’s a possibility the rack got effed up.
Old 03-24-2020, 07:45 PM   #4
Junkyardspecial
Hit one but with the right rear from the sound of it. Its possible though. Im curious to see how common it was, but hopefully the dealer can help tomorrow.
Old 03-24-2020, 09:18 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
it is common enough to have read about the psycho steering rack more than a few times...this happens mostly at track events or driving aggressively like you mentioned.
Old 03-24-2020, 09:29 PM   #6
Junkyardspecial
Really? I cant find anything on it. Is it damaged or is it just something that eventually goes back to normal.
Old 03-25-2020, 05:38 PM   #7
Stephen12ZL1
Drives: '21 ZLE A10
https://www.camaro6.com/forums/showthread.php?t=501882
Old 03-26-2020, 01:00 AM   #8
primecut
Drives: Chevy Camaro Zl1 1LE 6MT
I just had a psycho steering wheel issue, but it was a bit different than yours. My "service power steering" notification came on and the steering started shaking violently, but with power steering still functional. It kept making noises and even shaking a bit after I shut off the car. When I restarted the car, it went away.
It's this issue:
https://www.camaro6.com/forums/showthread.php?t=485889
I'm gonna take it in asap, masks, gloves, and all.
primecut is offline   Reply With Quote
Old 03-26-2020, 08:06 PM   #9
Junkyardspecial
Thanks for the replies gentlemen, the dealer said i definitely messed the gear up inside, they think i cracked it or knocked a tooth off of it. Either way im getting a new one under warranty.
Old 03-26-2020, 08:26 PM   #10
Scottyz
Scottyz's Avatar
That’s good. Especially them covering it under warranty. Stand up for sure.👍
