Old 03-22-2020, 08:08 PM   #1
CDFF
Drives: 2018 ZL1 1LE
Supercar 3 wider than Supercar 3R?
So I just received some Supercar 3‘s in ZLE sizes and stacked them up next to a set of ZLE wheels I have with 3R’s on them. Both stacks are 2x325/30/19 and 2x305/30/19.
Are the supercar 3’s wider then the 3R? Once I mount them and use them will they narrow to match?
I guess I will find out once I get them mounted up and put some miles on them.
CDFF is offline   Reply With Quote
Old 03-22-2020, 10:02 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
wow!
Old 03-23-2020, 09:33 AM   #3
Matos1LE
Drives: SS 1LE
I think you would need to mount them in order to have a proper comparison.
Matos1LE is offline   Reply With Quote
Old 03-23-2020, 10:48 AM   #4
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
eh just throw them on. Just more rubber to keep you planted now.
Jaxcam02 is offline   Reply With Quote
Old 03-23-2020, 11:54 AM   #5
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I would say throw a tape measure across both sizes of the 3s on the inside to get a bead to bead measurement. If the 305s are more than 11" and the 325s are more than 12", then you know the wheels will be pulling in on them and make them more narrow. That seems like a large difference though.
Old 03-23-2020, 11:58 AM   #6
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Both mounted on same size wheels ?
ing for grip.
http://www.motorsportsne.com/
Old 03-23-2020, 12:28 PM   #7
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
I have a new set of both G3 and G3R's unmounted I just measured individually and all together. The G3's unmounted are 9.5mm total wider Section Width than the G3R's unmounted (305 & 325/30/19). Anyways...the G3’s are a fat set of tires, and the G3R's are not exactly skinny ones for their given sizes. That's the top of the stacks of four new tires each.
RUQWIKR is offline   Reply With Quote
Old 03-23-2020, 12:38 PM   #8
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
According to Tire Rack, the rears are exactly the same for both the 3 and 3R. 13.0 section width, 12.3 tread width, and 26.3 diameter.
The fronts are slightly different. For the 3's, 12.3 section width, 11.6 tread width, and 26.3 diameter. The 3R is the same other than tread width which is 11.3.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 03-23-2020, 12:42 PM   #9
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Specs vs. reality are different. About 2mm wider per tire total Section Width unmounted.
Old 03-23-2020, 12:46 PM   #10
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Tire Rack is a pretty good source. Just passing along useful info.
It would seem that unmounted would be meaningless. Everything about tires and suspension should be based on operating conditions, no?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 03-23-2020, 01:04 PM   #11
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
TireRack is an excellent source, but, the tires are not going to get narrower mounted. Of course, there is a different tread design, tread compound, and shoulder design between the two.
I just wanted to compare unmounted to unmounted where the original poster had mounted G3R's vs. unmounted G3's.
Old 03-23-2020, 01:22 PM   #12
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
True. But who knows how the tires were stacked in the warehouse, compressed, etc.
Interesting that the front tread widths are different, unless a typo on their site.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 03-23-2020, 01:30 PM   #13
3.8TransAM
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula
Welcome to the world of tires. Diameters and widths do not match between manufacturers and your lucky if they do within the same line.
3.8TransAM is offline   Reply With Quote
Old 03-23-2020, 09:38 PM   #14
Mountain
Mountain's Avatar
Unmounted vs mounted, yeah a tire will likely get narrow in terms of section width, but tread width will be tread width. It's not like material all of a sudden disappears.
I mean, you also need to consider an unloaded vs loaded mounted tire too.
If the 305 SC3 is wider than the SC3R, you may not get that extra tread to the main contact patch, but it will be there rolled more onto the sidewall, which can mean something depending on your alignment settings and suspension. So instead of rolling onto the sidewall or end of the tread, you roll onto more tread or are less at the end of the tread.
