Old 03-17-2020, 03:03 PM   #1
RJLind22
Drives: Chevrolet Camaro
How wide can I go with my 2018 ZL1 Tires
I have a 2018 ZL1 not 1LE that I want to put wider tires on the factory 20" rims without it rubbing or having to relocate the wiring harness. Who has went wider with no issues and what did you go with?
RJLind22 is offline   Reply With Quote
Old 03-17-2020, 04:04 PM   #2
PROMETHEUS
PROMETHEUS's Avatar
You can go 295/30 in front and 315/30 in the rear on the stock wheels. However, you can most likely go bigger if you are using different wheels with different offsets and/or spacers.
Old 03-17-2020, 11:33 PM   #3
Flexhorn
Drives: A10 ZL1
I tried to use MT 305/35 20’s but got error messages. I have since relocated the wiring harness and ordered the Toyo88r 315/30/20’s
Flexhorn is offline   Reply With Quote
Old 03-18-2020, 06:26 AM   #4
Intimidator
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1
I have 295/30/20 PS4's in front, and 325/30/20 Sport Cup 2's in the rear on MRR wheels and stock offsets....and No Issues.
Intimidator is offline   Reply With Quote
Old 03-18-2020, 10:15 AM   #5
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
I am running 315/30-20 on the rear of my 2018 with no issues. I did pull both rears off and check for rubbing or loose wire harnesses. It all looks great.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 03-18-2020, 05:05 PM   #6
Kerry
Drives: 2019 2SS Camaro
Thinkg of those cup 2s for my car. Did they help take off from a dig?
Kerry is offline   Reply With Quote
Old 03-18-2020, 09:41 PM   #7
Markoz28
Drives: 18 ZL1 nightfall grey A10
I’m running 295/30/20 on custom BC wheels in stock front size and 325/30/20 on a 20x11.5” wheel with +41 offset. Fits like a glove
Markoz28 is offline   Reply With Quote
Old 03-19-2020, 08:12 AM   #8
Fredtp
Fredtp's Avatar
Drives: 2019 ZL1 A10 Black Mosaic
Can you post some pics?
Is your car lowered?
2019 Black Mosaic ZL1 A10
Kong Ported SC, 2.3 Grip Tec, Roto-Fab Big Gulp, NW103 TB, Mighty Mouse CC, ADM Expansion Tank, ARH 1 7/8 Headers, Catless 3" X-Pipe, Corsa Extreme, Eibach Springs, BMR Cradle Lockout, BMR Trailing/Control arms.
Fredtp is offline   Reply With Quote
Old 03-19-2020, 10:57 PM   #9
Markoz28
Car is not lowered.
Old 05-13-2024, 06:36 PM   #10
chris'stransam
chris'stransam's Avatar
Drives: 2014 1LE , ZL1-1LE , 1999 WS6
Do u all think I can use a 325 30 20 on my 20x11 et43 on my 2017 zl1 ?
chris'stransam is offline   Reply With Quote
Old 05-13-2024, 07:09 PM   #11
Z OH 6
Drives: 2024 CT5-V Blackwing
I have seen a person on a FB group run a 345 on the rear on the stock wheels. I don't know if I would trust that myself but the owner claims he's never had any issues.
Old 05-14-2024, 11:48 PM   #12
Vigilante375
Drives: 2018 Camaro ZL1
I dont believe the width has anything to do with the rubbing issue. It's the height.
But it literally takes maybe 10-15 minutes to relocate the harness.......
