![]() Drives: '20 ZL1 M6 Join Date: Apr 2017
Air filter
I’m still in the learning process with my first ZL1. Since these cars are forced induction, ingesting a lot more air, does an aftermarket high flow filter increase power? Thanks.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
![]() Drives: 2019 ZL1 Join Date: Oct 2019
Better off removing the snow ingestion blockers in the bumper area to allow the airbox inlet to get more air. I didnt notice any change with a Green filter aftermarket for the stock box. The inlet opening up def helped make boost quicker though.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I agree with Nemo that it didn’t make a difference in my ZL1. I bought a Summit Racing brand panel filter and can’t tell any improvement except that it can be cleaned and oiled just like a K&N filter instead of buying replacement filters to throw away when dirty.
#4 | |
TEXIT
Drives: 2019 ZL1 M6 Join Date: Aug 2018
Can you elaborate on this snow blocker mod? |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
Green filter and a ported TB. Combined they cost less than a CAI and are a better up front mod IMHO.
Flyin NOE
#7 |
Petro-sexual
Are those blockers behind the headlights, at the entry to the air box or something?
#8 |
There’s a small plastic piece that partially blocks the air inlet behind the grill on the air induction side for a true ram air effect into the stock airbox! That’s what Nemo was referring to in his reply.
#9 |
Easy removal?
Mal
#10 |
Sorry Mal, not sure about it! Send a PM to FoundNemo if you want to ask him questions on how to do it!
#11 |
Grab a Rotofab intake. They will make legit power, won't void your warranty and look good under your hood. Hit us up and we'll get you a great price.
#12 | |
Also, oiled or dry? Why do you offer both and what's recommended for a street only car? Thanks.
Mal
#13 |
Also, any independent dyno numbers by forum members who have the Rotofab installed on a stock motor?
Thanks.
Mal
#14 |
To pull the blocking plate, remove the upper radiator shroud (careful its sharp) and the annoying to get to hood latch, let it dangle. You can reach down and pull the pry pins out to remove the black plastic piece. Then reinstall the rest. Not super hard, just an annoying job.
