TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V6
Old 03-13-2020, 07:05 AM   #1
alice
alice's Avatar
Drives: 2010 camaro limited edition turbo
POST YOUR BOOST PSI ON LLT AND LFX
Since there are a lot of turbo and supercharger LLT & LFX members on the forum, I am interested in what PSI boost levels your projects are running, so could we use this thread to record those levels, as well as if any internal modifications have been made? I think it would be interesting to compile this information for those who are curious.
alice is offline   Reply With Quote
Old 03-14-2020, 07:37 PM   #2
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
7 psi
gutterball is offline   Reply With Quote
Old 03-15-2020, 07:26 AM   #3
alice
alice's Avatar
I have (2) settings on my boost controller. 7PSI & 10PSI.
Old 03-15-2020, 07:24 PM   #4
gutterball
gutterball's Avatar
How much HP at those Boost settings and what did you do to the Engine to take the extra HP - Im at 400 to the wheels and a little reluctant to go higher
Old 03-16-2020, 10:13 AM   #5
2012SIMRS
2012SIMRS's Avatar
Drives: SC 2012 V6
Running 16psi on stock motor
Supercharged V6 - 11.756 @ 122.75MPH
2012SIMRS is offline   Reply With Quote
Old 03-16-2020, 09:31 PM   #6
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Upgraded HPFP and injectors?
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
Old 03-16-2020, 10:40 PM   #7
2012SIMRS
2012SIMRS's Avatar
Drives: SC 2012 V6
At the time for 16psi it was just methanol, injectors were added to try and run e85 for that boost.
Old 03-17-2020, 07:23 AM   #8
alice
alice's Avatar
WOW! That is the highest boost level I have ever heard of on these engines. What level do you run on 93 octane gas, if you do? Who did the tuning? Very interesting!!
Old 03-17-2020, 09:48 AM   #9
2012SIMRS
2012SIMRS's Avatar
Drives: SC 2012 V6
Ran 16psi on 93 octane with methanol injection support, Will at Overkill did the tuning.
Old 03-17-2020, 07:15 PM   #10
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
8.49PSI
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 03-18-2020, 08:53 AM   #11
alice
alice's Avatar
That is sweet! Sorta figured Will did the tuning. He is one of the very best and a really nice guy. I met him and he knows his stuff. Your boost level is really unbelievable for 93 octane and meth injection. Crazy for a high compression engine with stock internals. Congratulations are in order! I'll bet that puppy is fast and is fun to drive.
Old 03-18-2020, 01:33 PM   #12
2012SIMRS
2012SIMRS's Avatar
Drives: SC 2012 V6
11.7 and 28mpg, couldnt be happier with that stock motor honestly. It is getting a major rehaul from intake, cams, fuel, and forged rotating assembly. It's all together and going in over the next few days so I cant wait to see what that will be like.
Old 03-19-2020, 09:25 AM   #13
alice
alice's Avatar
What a killer machine! I am so impressed and I have done a lot of FI installs! I may have to talk to Will about raising my boost. Love the HP!
Old 03-27-2020, 11:17 AM   #14
The camaro show
The camaro show's Avatar
Drives: 2015 camaro 2lt
They can run much more, I've seen 30-40psi and 600-700whp out the lfx.
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5
Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85.
The camaro show is offline   Reply With Quote
