Old 03-12-2020, 05:39 PM   #1
Hulkamaniac
Livin' the Dream
Hulkamaniac's Avatar
Drives: '23 Charger GT, '23 Stingray
Question 2019 Camaro Reverse Lights
I went cover to cover in my owner's manual, Googled, and even called the parts department at the dealership(I have a GM part number, but no other number) and no one can tell me what the replacement bulb is for the reverse lights on my 2019 Camaro. Can anyone help me out? Thank you in advance.
I plan on switching to LED's and hopefully Diode Dynamics has a set that doesn't require a special harness.
Chevy dropped the ball on the marker lights(again) and the reverse lights(again). LED's last longer, provide better light, and look cooler.
If you spell Chuck Norris in Scrabble, you win. Forever.
Hulkamaniac is offline   Reply With Quote
Old 03-13-2020, 08:03 AM   #2
NEGXXIS
NEGXXIS's Avatar
Drives: 2019 Camaro SS A10
I used these on my 2019 Camaro SS, they work perfectly.
https://store.ijdmtoy.com/products/l...-20-001a-white
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11
RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453
SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/
NEGXXIS is offline   Reply With Quote
Old 03-13-2020, 08:35 AM   #3
ryan01
Drives: 2020 Camaro LT1
I was going to do the harness till I realized on the '19 and '20 models the bumper has to come off to remove the tail light housing. I just did the resistor and gen5diy bulbs and that worked great.
ryan01 is offline   Reply With Quote
Old 03-13-2020, 09:51 AM   #4
Hulkamaniac
Livin' the Dream
Thanks you guys!
Old 03-17-2020, 11:30 AM   #5
NEGXXIS
NEGXXIS's Avatar
I installed mine without removing the rear bumper.
Old 03-17-2020, 12:07 PM   #6
ryan01
Oh I did too. It would just be easier to take the lights out which you can't do unless you remove the bumper.
Old 03-18-2020, 11:26 AM   #7
NEGXXIS
NEGXXIS's Avatar
exactly.
Old 03-29-2020, 04:04 PM   #8
20Bluezl1
I'm trying to find led reverse light for my 20 zl1 but I cant seem to find any. I have heard of issues people have replacing the bulbs. What is the best route to take without having issues?
Old 10-13-2020, 11:56 PM   #9
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Thread bump. I thought I'd just settle with halogen bulbs, until I visited a friend's place last night and I couldn't see anything that's not lit up by the LED license plate lights. So yeah, I ordered a pair of VLED HO6, and this is something I would have to deal with when they arrive.
I will try to attach small resistors first, but in case that doesn't work, I will grab the harness.
How did you go about doing that? I took a few pics under the bumper today and it looks like you may be able to reach the connector by jacking the car up and reaching it from below the car. Not 100% sure if this would work, though.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 10-15-2020, 05:54 AM   #10
Zapote21
Tampa Bay Camaros
Zapote21's Avatar
Drives: 2017 Krypton Green 2SS
With the ijdmtoy kit mentioned above, each bulb has its own harness and resistor. No need to remove the bumper. Simply change the bulb and attach resistor as shown on these pics.
Me and wife, in order
2011 2SS SGM
2013 2SS Hot wheels vert
2016 C7 DSOM
2012 2SS yellow vert
2017 2LT Krypton Green
2018 2LT Hot wheels crush
2020 2SS Shock vert.
2017 2SS Krypton Green coupe
Zapote21 is offline   Reply With Quote
Old 10-15-2020, 09:21 AM   #11
FrostZ
FrostZ's Avatar
Drives: 2019 A10 ZL1
I did the Gen5DIY harness on my 19Z for the LED’s and it can in fact be done without removing the bumper. I was able to slide my arm up into the bumper cavity from the diffuser and disconnect the harness mostly by feel. It can be a pain to disconnect but once you do it’s a simple plug and play! I’d take note that those resistors had a lot of room to bounce so I zip tied them to the harness to limit that, but it is possible with some patience and nimble hands
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
FrostZ is offline   Reply With Quote
Old 10-15-2020, 02:36 PM   #12
UnknownJinX
Thanks for mentioning this option, but I prefer the VLED HO6 bulbs as the chips are aligned with where the filament is in the halogen bulbs. It would replicate the beam pattern better than most other bulbs on the market.
Thanks for confirming my thought. If it has to come to buying the Gen5DIY harness, that's what I will do.
Current:
Past:
Old 10-16-2020, 10:36 PM   #13
UnknownJinX
Welp, got it working with a 200 ohm resistor. No glow and reverse cam shuts off properly. Only installed it on the driver side LED.
I will probably get a higher wattage resistor. I used a 1/4 W resistor which is below the wattage it will see during usage.
P=V^2/R, so (14 V)^2/200 ohm=0.9ish W. It worked okay in the short durations I left my reverse on, but in the long run, I will get and solder a 1 W resistor on just to be safe.
Current:
Past:
Old 10-19-2020, 10:59 PM   #14
UnknownJinX
Quick snip of the backup lights at the gas station.
So much better now.
Sent from toaster or something
Current:
Past:
