![]() Drives: 2020 LT1 Join Date: Dec 2019
Cammed '20 LT1
This friday, I'll be installing the GMPP Hot Cam, Speed Engineering 2" longtubes and a flex fuel kit. It's getting tuned at Speed Inc. In Schaumburg IL on monday. I've lowered it with AFE springs and switched to 19x9-19x10s. The bare trunk looked so bare, I installed the GM "high spoiler". I chose this cam for the low lift. I drive 30k a year, so annual valve springs didn't appeal to me. Fingers crossed it puts down at least 450.
2020 Shadow Gray 2SS
Looks great!
(Seeing "Schaumburg" made me sad... Grew up in Des Plaines (21 years), lived 3 years in Palatine, 7 years in Lake Zurich and 11 years in Cary)... I know exactly where Gilberts is...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
450? You'll make 450 with headers and flex fuel. Those are rookie numbers! 475-490 depending on cam specs.
Wow, that install wasnt fun. I opted to not drop the oil pan and peel the chain off of the phaser. Took 3 trys to get it timed properly. The speed engineering system leaks terribly. I initially put it together with 3x3 clamps, but they didn't tighten enough, so I then caved and used the narrower clamps that were provided. The idle sounded healthy, but went into limp mode when attempting to pull it out of the shop. I had it towed to Speed Inc for the tune tomorrow. Another issue was the pin location for the flex fuel. It's got to be different than earlier years, because there isnt a removable plug in said hole in connector. While the car was down for install, I had the wheels powdercoated and put on some beefier summer tires. I hope I get some good news tomorrow!
Fun day
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Nice build! In for results. Any plans for the intake manifold?
#7 |
Not at the moment. I'd like to drop another 2k on a mamo MSD and a rotofab, but that's not feasible yet.
#8 |
Today it put down 479 on 93. E tuning will be happening tomorrow.
#9 |
Awesome!! Keep us updated.
#10 |
![]() Drives: 2019 Camaro 1SS A10 Join Date: Nov 2015
So you still have the stock airbox, stock throttle body, stock intake manifold and stock exhaust(besides the headers of coarse)?
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6 2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD** 2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD* 2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD* |
#11 |
500 on E?
#12 |
499/447 on E. Peak hp at 6200. Doesnt stock peak at 5700? So appx. 100 wheel from the hot cam, 2" speed engineering longtubes kit and the flex sensor. Car really rips now. I got laid off today. So on my 45 mile commute home on the expressway I was able to get acquainted with the new set up. Stock air box, filter and non npp mufflers. Chops good at idle, makes its presence know at WOT, but with zero drone. With the radio on, it's no different than stock. Big thanks to the crew at Speed Inc. They adjusted and clamped the exhaust, so there are no leaks. Including tune, I've only got about $3k into this simple set up.
#13 | |
#14 |
Yes, M6. It's got some low speed, low rpm surge in first. Power is a little "spongy" when hitting it at a lower rpm compared to stock. With the little time I've had, it seems the remedy is just drop a gear to end up in the powerband. 3500 and up its responsive. My tire height may also be a contributing factor. At 28" tall, they're only .3" taller than stock, but I think the 1le height is in the upper 26s if I remember. I wanted a 28, because I've also bought a pair of 17x9s to put 28x10 Hoosiers on, and didn't want to freak out the traction control/abs. Stabbing it from a roll out, I did get some wheel hop, so some BMR goods is next on the list. Thanks for the kind words about my lay off. I'm a 14 year Hyundai tech, hoping things turn back around in a couple weeks.
