Old 03-06-2020, 05:21 PM   #1
SienarSystems
SienarSystems's Avatar
Drives: ZL1 1LE
Big Gulp + 2650 = Rubbing
Anyone else with a 2650 and Big Gulp experience this? Looks like one of the hood bolts is rubbing the silicone coupling hose between the air box and hard tube feeding into the tb. I removed the bolt and the hose is not punctured. Still looking to replace the silicone coupling. Anyone know the part number? I reached out to Rotofab and did not get a response. And, anyone know where to get the flat head bolts Rotofab provides with the kit? Thanks!
SienarSystems is offline   Reply With Quote
Old 03-07-2020, 07:05 AM   #2
laynlo15
Drives: 2022 Lt1 A10
If it didn't rub thru just loosen the clamps and rotate it to the bottom. No need to buy a coupler.
Old 03-07-2020, 07:49 AM   #3
Omega
Drives: G8
I believe it's 5" dia. The clamp seen in your pic shows it's for 120-140mm tubing, so 5" sounds right
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 03-07-2020, 08:01 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If you don't drive in the rain a lot, I'd just leave it off, and maybe throw some towels over that area in the engine compartment when you wash it. That's what I did, anyways, but I don't drive it in the rain. Maybe try Fastenall. I think if you do like a "button head bolt" in the correct size on Amazon you could probably find one. I know of a place be me where I bet I could find them.
JMHO.
My memory was wrong... you have to replace those fasteners... duh. Still - maybe consider the above. I know the bump from the standard RF to the BM was worth like 20-30 RWHP on an 800-RWHP car through dyno testing (CSP's video on Andrew's ZL1).
'20 ZL1 Black "Fury"
Old 03-07-2020, 09:04 AM   #5
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
How do you not have Mike w rotofabs personal cell?
I though you maggie boyz where the fastest? I got it! but of course i worked with him on the 112 stuff because the eforce blower was out 1st!
just kidding if ya need it let me know!
Old 03-07-2020, 10:34 AM   #6
SienarSystems
Drives: ZL1 1LE
Thanks all. @EDF - Mike only gives his cell # out to people with port injection so I’m out of gas...seriously I think the lack of response has something to do with my zip code and the fact that Rotofab does not sell to folks in CA. Guess I could just cut a giant hole in my hood and call it a day, right EDF?
Old 03-07-2020, 01:05 PM   #7
laynlo15
I have it but I don't give it out unless Mike tells me its ok. I've known him since 2008, good friend. Just go to hardware store, its probably an M6 1.25 thread or just take that bolt with you and buy a phillips head bolt for it. Yes you are correct.
Old 03-08-2020, 08:17 AM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That cutting isn't for the faint at heart, like a person like me, hahaha.
Old 03-11-2020, 08:42 AM   #9
ShizzySupra
Drives: 16' Camaro 2SS
All E Force poser talk aside:
Why do you have a 2650 and a big gulp with stock throttle body?
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 03-11-2020, 08:46 AM   #10
laynlo15
Shizzy, he has the 95mm Lt5 but I think he is planning a 103 someday after some more mods.
Old 03-11-2020, 11:20 AM   #11
SienarSystems
Drives: ZL1 1LE
Correct, I have a ported 95mm. Will address fueling and add the 103 or 112 tb and snout after my move.
Originally, I had the stock airbox and tb in order to be Magnuson’s CARB test mule.
