Old 03-05-2020, 01:30 PM   #1
Feefsmaro93
Drives: 2016 white 1ss A8
Long tube headers
I have 2 inch speed engineering headers on my car had vbands welded to the collector and ypipe and the rest is borla mids to a awe axle back which is fully welded as one peice so the only clamp would be the vband and i have no leaks but next to walls and in tight blocks i can hear a ticking or almost like a clicking sound bouncing off things i checked the vband for leaks and have none also checked the mating surface to the heads no soot. Is this normal with headers first time driving a car with them?
Feefsmaro93 is offline   Reply With Quote
Old 03-05-2020, 01:39 PM   #2
Bohanan23
Drives: 2016 Camaro 2SS A8
Waiting for people with overpriced headers to comment "you get what you pay for" LOL my guess based off your explanation is the normal injector ticking from the LT motor. When I installed mine on my 14 Silverado I remember it being a little more pronounced.
Bohanan23 is offline   Reply With Quote
Old 03-05-2020, 04:52 PM   #3
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
Yeah, they're pretty noisy even without leaks.
A good way to test is by pressuring up your exhaust and using a spray bottle filled with some dish soap and water. Do it with the engine and exhaust cold. Get a shop vac. Clean it and configure it to blow. Tape the nozzle into one tailpipe and seal the other (tape or a bag or latex glove or whatever). Spray the soap and water on every joint and the head. It's the easiest way I know to find leaks.
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 03-06-2020, 09:28 AM   #4
Feefsmaro93
Yes its not a leak i went back to the shop they did that with me under the car i saw for my self and felt around the pipes for leaks no soot either just i guess its exhuast gas pulsation mixed with di and valvetrain noises haha
Old 03-06-2020, 03:24 PM   #5
oldman
Drives: SS 6 speed of course
I have Borla mids, IMO, this is not a Borla issue, it is an issue with anything that replaces the two small flex joints in the system. My exhaust does vibrate now, sometimes at idle I can hear the rear rubber hangers making noise as the flex. I kind of knew it was going to happen and will weld in at least one flex joint. Without at least one we are talking about a rigid system from engine to tailpipe, hence the factory put in two flex joints. So this is any issue with any aftermarket system that starts or has pipes that replace the factory twin flex joints.
oldman is online now   Reply With Quote
Old 03-06-2020, 05:54 PM   #6
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I installed kooks and same thing I hear a ticking, I think its just the nature of the beast. On a side note, theres alot of rattling coming from my motor, like npp rattle but up front. I think it might be the stage 8 locking washers rattling as they weren't all tight. Could that be it maybe?
Old 03-09-2020, 08:14 PM   #7
Feefsmaro93
I dont have any locking washers its just the thin metal from the header went under the car and ran it i dont feel any leaks or see any
Old 03-09-2020, 08:17 PM   #8
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Normal. Headers are thinner than the stock manifolds. You are hearing either the exhaust pulses or the thinner metal expanding and contracting.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 03-11-2020, 10:40 PM   #9
Feefsmaro93
Its only at certain rpms and speed
Old 03-12-2020, 08:58 AM   #10
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
This, I hear it with my speed engineering headers on my LS1 cammed camaro.
Jaxcam02 is offline   Reply With Quote
Old 03-12-2020, 03:03 PM   #11
oldman
IMO, the removal of the two factory flex-joints with the Borla mid-pipe is the issue, you basically have a solid 1 piece exhaust, the ticking etc is caused by the exhaust expanding and vibrating. It is a potential issue with all aftermarket systems at the mid-pipe (all that I know of).
Old 03-13-2020, 07:40 PM   #12
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
did you check to see if the exhaust is hitting anything. check hot it expands.
