Old 02-27-2020, 11:02 PM   #1
GHOST_1LE
Drives: Camaro ZL1 1LE
Bogging down
I was cruising at like 60mph in 5th gear and I slammed the throttle wide open and the car just bogged down kinda shook and I had absolutely no acceleration at all. At that moment I smelled a faint sulfur smell. This is the second time this has happened in less than one month of me owning this car. The first time it happened when I pulled into my subdivision going about 20mph in second gear, punched it and had nothing. This time I smelled what I thought was burning rubber. This is not a constant problem. I pulled into my driveway, turned the car off, I went out 20 minutes later and took it out for a test drive and it was fine. I do have a code on my PCM P0451. I know this code has to do with the EVAP system, any correlation? Anyone have any ideas as to what the problem could be before I can get it to the dealer for them to look at and tell me that they can’t replicate the problem. Has anyone ever ran into this problem?
GHOST_1LE is offline   Reply With Quote
Old 02-28-2020, 08:01 AM   #2
Vigilante375
Drives: 2018 Camaro ZL1
Is the car stock or modded?
Old 02-28-2020, 02:22 PM   #3
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
I doubt it is a coincidence. The CEL should give the dealer a good clue. Could be a variety of things, sounds like somehow your car went into an over rich (fuel) condition. Keep us posted.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 02-28-2020, 06:59 PM   #4
Nucdancer01
Drives: 2019 Satin Steel ZL1 1LE
Clutch smell?
Nucdancer01 is offline   Reply With Quote
Old 02-29-2020, 05:54 AM   #5
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
Were do you get your gas at ? And do you only put gas in it ?
Revalot is offline   Reply With Quote
Old 02-29-2020, 08:05 AM   #6
Kerry
Drives: 2019 2SS Camaro
Traction control will do that. Try it with it off
Kerry is offline   Reply With Quote
Old 02-29-2020, 09:24 AM   #7
6spdhyperblue
Drives: 2SS 1LE
Is your foot totally off the clutch pedal?
If not clutch protection is kicking in.
Could be a vacuum leak too
