02-27-2020, 05:03 PM | #1 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Drag racing tomorrow. Please help
So the car makes more power now. 780/800. Car made before 612/642 and ran 11.1 at 129. That was on R888Rs. I now have 305/45/17. This will be my first pass ever with drag radials.
Things I need to know What settings do I put the car at? What PSI should I start the rear tires? Front tires are 295/30/20, what tire pressure? How long of burnout? Anything else would be appreciated. |
02-27-2020, 07:16 PM | #2 |
Two Lane Blacktop
Drives: '18 Camaro 2SS Join Date: Jul 2019
Every car is different, every day temp and humidity is different, and every track is different.
Get a notebook, browse some of the drag/ launch threads to get a base line and record what you did and changes you make. See if you get some tips from racers in the pits |
02-27-2020, 09:29 PM | #3 |
02-27-2020, 10:11 PM | #4 |
fronts at 40 psi...start with rears at 19-20 and adjust in 1 psi increments to a min of 16. My opinion is to start with a slightly higher pressure because you will be above 130mph and the rear may be a bit squirrely on the top end.
Default via the screen...exhaust to track (if applicable) and suspension to tour. Turn off traction control/stabilitrak with a 5 sec hold of the TC button. Put mode switch in "track" and launch in D. Let the computer shift itself...no paddles. Burnout 3 seconds and roll forward with the wheels spinning, pull to line, stage, & go. Don't get too crazy with launch rpm and brake torque to 1100rpm or so to load the car. Adjust launch rpm depending upon available traction. Good luck.
02-28-2020, 05:47 AM | #5 |
AXLERODZL1
Drives: 2019 Riverside blue ZL1 Camaro Join Date: Dec 2018
20psi would be my lowest on a track with a street car that has high trap speeds
'19 ZL1 A10 Riverside Blue PDR/Nav/Sunroof
Kong ported blower/snout Roto-Fab Big gulp 103 TB Lingenfelter Lower Pulley(9.17) 1 7/8 ARH headers and Exhaust Meth injection(single nozzle) 733whp/788tq |
02-28-2020, 08:06 AM | #6 | |
Put it in touring mode Pump them up as much as they will hold! New tires? it will take a pretty good burnout to get them sticky! Leave off of idle and see what it will do then leave at like 1500. The higher the pressure the better on the M/T start at 19 and see if it hooks Good luck! Report back! You should be in the 9's if it hooks! a 1.4X 60 foot would be nice!
2019 COPO #32
427 NA 9.38 142MPH 2018 ZL1-NFG-A10 388CI L8T 9.32 147MPH Last edited by 2018ZL1; 02-28-2020 at 08:37 AM. |
02-28-2020, 08:19 AM | #7 |
My best et at 9.41@146 w/1.35 60 ft came with 19 psi in the rear 305-45-17 MT Rs. Start my burn out in 1st at about 6000 rpms and then once there spinning and starting to smoke shift it into 2nd gear and once it starts to bring the rpms down let off the brake and head to the line. Just roll thru the water a couple feet and then start your burnout. If you start it in the water in ends up in the liner and then drips down on you slicks and won't hook like it will if you do your burn out past the water. Don't forget to put it back in drive at the line. Really embarrassing to forget that. Haha
02-28-2020, 07:06 PM | #8 |
All great info. Heading to the track now. Thanks everyone.
02-28-2020, 08:18 PM | #9 |
Have fun and good luck. Lets see some great times.
02-28-2020, 11:05 PM | #10 |
Long story short. Track very sticky, broke the drive shaft on 2nd run
02-28-2020, 11:38 PM | #11 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Ah shit. Well you know it’s making power.
02-29-2020, 01:53 AM | #12 |
Sure is. Going to look at the damage tomorrow and fine out what I need.
02-29-2020, 05:50 AM | #13 |
Did you have a loop? Can you take a pic of the damage?
02-29-2020, 06:30 AM | #14 | |
