Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
Flex fuel now working on 16&17 model years.
ZZP made the announcement a few days ago, and after some trial and error I have confirmed it is working in HPTuners with the latest Beta release!!! Still pin 70 on the X3 connector.
![]() Drives: 2017 Camaro 2.0T RS Join Date: Jul 2018
Fricken finally, HPTuners just needed that final push haha. Super excited about this, no more mixing fuel etc.
We've updated the instructions to reflect the pin for the 16+ cars, but if anyone has any questions regarding the kit, wiring etc let me know!
![]() Drives: 18 Camaro LS M6 Join Date: Apr 2019
What about 2018?
. . NFG M6 2T Mishimoto Hot side pie | ZZP Catted DP | KN Drop in | Borla - Sport Tour | Apex Arc 8 - square | Wookster Tuning+ | Flex Fuel Last PB 4.8, 13.2@106 |
Coopers Camaro
18 has been unlocked since Feb of 2019.. At least that's when I got mine working in HPT.
![]() ![]() Drives: 2016 M6 2.0T Join Date: Nov 2016
I have so many questions about this. Just to clarify a few things:
Do you need to compleatly re-tune the car for the kit to work? Is it just plug it in and go? Will the car automatically adjust to any type of fuel mix? Will the car see HP gains on it's own automatically with E or an E blend?
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
#6 | |
Coopers Camaro
Yes, the car needs to be tuned VERY differently for running E mixes. Even things like start up, and cold cranking will need adjustments.The car will adjust for ANY mixes, yes, as long as the tune is set up properly for it, and as long as the fuel system can handle the blend. Third question is Yes, but once again, that's assuming the tune is set up properly for flex fuel. I can not stress enough, the tune needs a TON of adjustments to do this correctly, and safely!!! But when its done right, you have just added yourself a nice little safety net for your 2.0T, and a decent chunk of power.
#7 |
Cooper your answer was a little cryptic. Do I need some special unlocking even if I can go in and play with my flex fule tables in "hpt' ? I have option boxes for external adapter fitted choices an whatnot. Also I found out that some one locally may be dealing VP fuel in a town nearby. Would like to look into it.
#8 |
Coopers Camaro
Wook, no special unlocking needed. Just the sensor, the latest HPT Beta, and set up your sensor table like so...
#9 |
It Can't be that simple. Can it? Am I missing something? was it that the 16-17 didn't have this tuner option and needed to be like coded or some such?
I guess I should check with Tyler but is the harness connection/instructions Very clear on how to connect on E80A?
#10 |
BYND GARAGE
Drives: 17' 1LT Turbo Join Date: Feb 2016
Wish I still had my 17.! What about 19+ ??
#11 |
I been looking at this tab for months, but b/c we are a dry state hadn't given it much thought. But I might have a lead on a local source of E85 jugs. I understand you can only dose half gas and half ethanol b/c the injectors were not planned for squiriting the equivalence volume of fuel at pure E85. Definitely considering getting the hookup though.
#12 |
Coopers Camaro
E50 is about the max for most guys. There are ways to run more, but I won't confuse the conversation with that. I do highly suggest guys running a blend, to go ahead and pay the 2 extra credits in HPT, and gain access to the LPFP tables, and tune those. Depending on how the tune is set up, even E50 can be very taxing on the stock fuel system, especially the LPFP. The VERY LAST thing you want to do to your LTG, is drain the fuel rail at WOT..
#13 |
didn't even know about LPFTP tables. so its not on the os upgrade menu, or wasn't last time I checked.? WM system still looking strong since it will cool the intake and I only plan to work it so it taxies in a limited window. Given 10 degrees of cool will yield some percent of gain, some say 10F to 3hp for NA.... curious. What say you?
#14 |
![]() Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
I'm wondering how this will play with port injection when ZZP has it ready.
