![]() Drives: 2018 ZL1 A10 and 2013 GT500 Join Date: Apr 2012
Stock ZL1 drag wheels with skinny fronts 1/4 times?
The title states it all. I have seen people times all over youtube with drag tires on stock rear wheels or drag rear wheels tipping 10.9s or so with the A10. Has anyone had a better time with lighter skinny in front? I am probably gonna start racing my car but going to leave it stock for now. Just seeing if the whole big and little setup is worth it. I will Probably get a set of welds.
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
I've ran a best of 10.86 with rear drag wheels and tires only. I would also be interested to know if there's much to gain with skinnies.
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
![]() Drives: 2019 ZL1 Join Date: Oct 2019
Did you run OEM front wheels/tires and curious what drag setup you used in the rear. I'm looking for a quick swap solution for rear drag setup that doesnt require tuning due to tire height differences nor brake clearance or MRC issues.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
skinnies are generally worth about .1 sec at this e.t.
#5 | |
![]() Drives: 1968 Camaro and 2019 ZL1 Join Date: May 2019
Yes. Factory fronts with 17x10.5 RaceStar Recluse wheels with Hoosier 315/35 DR2 drag radial. These rear tires are over an inch shorter than stock, but the only issue with that is sometimes causing traction control to engage if you're driving with it on, and the speedometer reading higher. If they ever make it in a 27", then I'd probably switch to that, so the speedo and TC are no longer an issue. TC is really no big deal because I always run with it off anyway, but I would like to have the speedo read right to have accurate PDR info.
