Old 02-23-2020, 05:48 AM   #1
Robby23
Drives: 2018 1SS M6
Wideband Bung
I am about to install my bung and i have been looking around on placement. I am installing headers as well that have catless connection pipes. Just got my headers freshly ceramic coated and don't want to weld in a bung on them if i don't have to. I've read put it before the cat because after the cat can make your readings off but since I am catless could I just put in right into the catless connection pipe?
Robby23 is offline   Reply With Quote
Old 02-23-2020, 07:39 AM   #2
6spdhyperblue
Drives: 2SS 1LE
I would go behind. So if you wanted to pull the wideband and install the rear o2s someday you just weld in one more bung on the other side
Old 02-23-2020, 11:43 PM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
should have had the bung put in befor they were coated but its no big deal to put one in after.
Old 02-24-2020, 07:06 AM   #4
Robby23
Drives: 2018 1SS M6
Lessons were learned. First time needing to do a wideband.
Old 02-24-2020, 01:18 PM   #5
JCunningham
Drives: 2017 2SS M6
you only need the bung if your going to be installing a gauge. if your getting a dyno tune they will remove your narrow band o2s and use those holes.
Old 02-24-2020, 07:57 PM   #6
Robby23
Drives: 2018 1SS M6
Yeah I got the hp tuner, wideband and aem x series gauge. Getting a pray tune remote. Next winter gonna try to sell gauge used and get a gauge that can show a/f and e-85 content when I do heads/cam. Just doing all the bolt ons this winter.
Old 02-25-2020, 01:16 AM   #7
JCunningham
Drives: 2017 2SS M6
I have a Innovative 3903 https://www.summitracing.com/parts/inn-3903. I have HP Tuners set up to read it. serial to usb.
