Old 02-22-2020, 03:57 PM   #1
Hadeszl1
Drives: 2017 Chevrolet Camaro zl1
Question about headers
Hey guys I might be picking up a set of kooks 2” long tubes and my question is is there anyways to set up a way where I can keep my npp and not have to cut or weld anything ?
Hadeszl1 is offline   Reply With Quote
Old 02-22-2020, 05:24 PM   #2
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Keep NPP? Yes.
Not cut or weld anything? No. All headers require at least some cutting/clamping/welding.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 02-22-2020, 05:45 PM   #3
Hadeszl1
Originally Posted by JonDaddy82 View Post
Keep NPP? Yes.
Thanks for the response I appreciate it. What would be the way to keep my npp then? Someone recommend I get the corsa mid pipe and use that with the kooks 2” does that sound right ?
Old 02-22-2020, 06:12 PM   #4
JonDaddy82
JonDaddy82's Avatar
Keeping the NPP is the easiest part. Only changing the exhaust BEHIND the rear axle will eliminate the NPP. Anything from the engine back to the rear axle is fair game.
Old 02-22-2020, 07:42 PM   #5
Markoz28
Drives: 18 ZL1 nightfall grey A10
Lots of ppl do this. I have Kooks 2” with no cats and connected to the stock NPP exhaust.
Any shop worth their weight will know what to do.
Markoz28 is offline   Reply With Quote
Old 02-22-2020, 09:04 PM   #6
Snowwolfe
Drives: CTV5 V Blackwing on order
Any hp gains with the headers without a tune?
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 02-22-2020, 09:11 PM   #7
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
It will not run right without a tune and will set off codes, remember if you have a warranty it will be voided once you have headers and tune also ! Good luck you will be fine !
Revalot is offline   Reply With Quote
Old 02-22-2020, 09:37 PM   #8
Hadeszl1
I will be doing pullies and a tune as well I also already have a intake but thanks for the Info and I’m not to worried about warranty got a buddy over there
Old 02-22-2020, 09:39 PM   #9
Hadeszl1
So if I do the kooks with the corsa double x pipe I should still have my npp correct? Thanks for the responses guys
Old 02-23-2020, 02:59 PM   #10
wanab
wanab's Avatar
Drives: 17 ZL1 4300 03/16/2017
I installed Kook's 2" w/high flow green cats and Kook's 3" X pipe to the rear suitcase muffler. The cut to the stock exhaust was dictated by where the 3" Kook's X pipe ended which was just in front of the stock muffler suitcase. I added a wideband O2 bung on the front side of the drivers side cat for tuning and ethanol content/AF gauge. I also had the headers coated by Jet Hot.
2017 ZL1 Coupe, MBM, A10, PDR, CF Hood Insert, ZL1 matts, 50th Anv. Indoor Cover
wanab is offline   Reply With Quote
Old 02-23-2020, 03:10 PM   #11
Yes, but not near as much as it will with a tune.
It will run fine without a tune... just leaving some HP on the table and the rear O2 sensor will set a CEL. Headers are going to void warranty anyway so might as well tune to get the full benefits.
Old 02-23-2020, 04:39 PM   #12
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
Kooks could connect without welding but you will have to cut
Zigg L1 is offline   Reply With Quote
Old 02-23-2020, 05:27 PM   #13
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Total waste of considerable money to add headers with no tune. Drivability is effected and you leave significant HP on the table all along the curve un-tuned. Under certain conditions you also risk going into an excessively lean condition which can cause engine damage.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 02-24-2020, 09:43 AM   #14
Juiced1
Drives: 2012 2SS CAMARO 45th
You could do this but there is a better option out there.
Just go with the Stainless Works long tubes. They run all the back to the factory NPP and replace everything else.
The Kooks and Corsa would have to be welded together. Any Xpipe that is designed to remove the rear cats will overlap with the headers connection pipes. So you'll need to cut the exhaust and weld it together. Cutting through 304 stainless is a pain too.
If you order the Stainless Works headers with full xpipe it all bolts right in place. You'll just need to make one cut in the back before the mufflers and then clamp it all together.
Juiced1 is offline   Reply With Quote
