Old 02-21-2020, 06:33 PM   #1
16CamaroSS
Drives: 2016 Summit White Camaro SS (2SS)
Power Stop Brakes
I'm going to show some ignorance here but please bear with me.
I'm sick of the brake dust on my wheels and the work it takes to keep them clean. My summers are in for ceramic coating but I figured adding some Power Stop Brakes would help all the more.
What I've read up on them, they're not great for tracking but fine for dailying which is what I do with the car.
So I ordered some pads off of Amazon only to see someone posting on Facebook that you can't go with just pads alone and that you need to either get the rotors too or at least have the rotors resurfaced.
Is it true that you can't simply drop in new pads and either need to resurface the rotors or swap out to new rotors?
16CamaroSS is offline   Reply With Quote
Old 02-21-2020, 06:46 PM   #2
MrRuss
MrRuss's Avatar
No you don't HAVE to have the rotors also. I had PS Ceramic brakes on 2 of my previous cars and they were fine. In fact on my son's 2000 Camaro years ago they were a ton better than the stock in stopping power. My SS has the Brembos, I went with Ceramic but don't remember the brand, they are also fine.
If the car shimmies when you brake or there are grooves in the rotor surface, they will need to be resurfaced/replaced. Mine were fine, I didn't resurface, that was about a year ago and ~ 6K miles. No Issues any my car currently has 40K miles.
Mr Russ
Tim "the tool man" Taylor is my hero
My Garage:
'16 Chevrolet Camaro 2SS, Summit White, Adrenaline Red
-- Rotofab CAI, Soler TB, 1 7/8 coated LT's, Full 3" mids, 3" Stainless Works NPP mufflers, Flex Fuel, E85/91 tuned
'20 Honda Oddysey Elite 25th Anniversary Edition
--wifes car, she said "No more SUV's" after the 2 CX-9's totaled
MrRuss is offline   Reply With Quote
Old 02-21-2020, 06:48 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
just do a light coat of sandpaper on your rotors before you drive it after you swap the pads out its super easy
Old 02-21-2020, 06:49 PM   #4
16CamaroSS
Thanks
Old 02-22-2020, 06:32 AM   #5
VinnAY
Drives: 18 1SS/1LE
I didn't even sandpaper or otherwise prep my 1LE/Brembo rotors, dropped in the Z26 and followed the break-in procedure...multiple hard braking 60-10 runs and Ive been good to go ever since. Great pads, 1000% less dusting.
Old 02-22-2020, 07:43 AM   #6
ride_002000
Drives: 2016 F150
It's good practice to swap rotors too if they have significant grooving from your old pads, but if they are smooth and little miles then should be ok.
ride_002000 is offline   Reply With Quote
Old 02-22-2020, 07:53 AM   #7
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
use a name brand brake cleaner, YES it matters!! scuff the rotors with 800 grit and you will be good to go. I wouldn't cut the rotors, they are thin already and once you overheat them you will start to get shimmy...:(
I DD my powerstops without issues. just know, you will lose the initial bite of the stock pads but they stop pretty good. 95% dust improvement.
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 02-22-2020, 07:53 AM   #8
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
I had the Powerstop Z26 on my 1LE for 4 months and just switched back to the factory Brembos 2 weeks ago. The Z26s didn't have near the same stopping ability and they squealed no matter what.
Old 02-22-2020, 07:58 AM   #9
JROC
Drives: 19 Camaro SS 1LE, 03 Ford Lightning
This.
I've gotten to the point where I don't even try bedding the brakes with multiple hard near stops when I do a brake job. I just go out and drive it for about 20 or so minutes making sure I use the brakes a decent amount during that drive. Never had an issue when doing this, but I lost about all my petal pressure one time trying to bed the brakes on my L by doing a bunch of hard near stops from 60+ MPH.
JROC is offline   Reply With Quote
Old 09-14-2020, 02:38 PM   #10
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Resurrecting this from the dead.
I need new Brake Pads. I hate all the dusting my stockers do, its a total PITA. But I don't want to lose 'too' much braking power. I eventually intend to track the car as well. Are the Power Stops for me? If not, are there any other pads you would recommend? Or would I need to swap to a larger caliper?
Need4Camaro is offline   Reply With Quote
Old 09-14-2020, 02:45 PM   #11
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Powerstops would be ok for dust reduction and street use, but keep your OE pads around and re-burnish them for use on the track. No such thing as a low-dust track pad, unfortunately.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 09-14-2020, 03:36 PM   #12
Need4Camaro
How are the Power Stop Z26 pads?
Old 09-14-2020, 04:22 PM   #13
Yellow Beast
TD
Yellow Beast's Avatar
Drives: 2017 2SS, 2014 Mercedes C300
Buy them. You wont regret it.
Yellow Beast is offline   Reply With Quote
Old 09-14-2020, 04:36 PM   #14
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I put them on my 2020 2SS at 400 miles because of the horrendous brake dust... Helped a huge amount!
