Old 02-19-2020, 06:07 PM   #1
jmackisback
jmackisback's Avatar
Drives: 2019 Camaro ZL1
Question Straight forward lower pulley question
Good evening.
I was wondering if someone could simply give me the lower pulley part numbers for 15%, 18% and 21.5% OD (and their accompanying manufacturers). I am about to do some modding with a dual nozzle meth set up and I cannot get a clear answer as to who makes the 18% OD lower pulley.
On a side note, what would a 18% and 21.5% OD pulley spin the stock blower at? Not looking to go much, if any, beyond the max efficiency.
Please keep in mind the car has intake, ported TB, headers and dual nozzle meth set up.
Thanks kindly in advance.
1987 Camaro V6
1988 Camaro IROC Z
1993 Camaro Z28
1999 Camaro SS
2017 Camaro SS
jmackisback is offline   Reply With Quote
Old 02-19-2020, 07:44 PM   #2
IneedAZ
IneedAZ's Avatar
This will tell you the rpm they will make the blower spin at. No part numbers though.
https://weaponxmotorsports.com/blogs...ng-mods-needed
Old 02-19-2020, 08:33 PM   #3
Markoz28
Drives: 18 ZL1 nightfall grey A10
Originally Posted by jmackisback View Post
Good evening.
Im not sure on the RPM's but since you are running meth, may just want to go up to an 18% which is like a 9.55" lower pulley. You could also do 9.1 lower and 2.3 upper which I think would net you about 21%. Would be a good idea to port the SC with either Kong, Jokerz, Or Modern Airflow Dynamics. You will be over 700whp with all of this and without touching a cam if that is not your desire. Also throw in 103TB or Soler 95mm with their adapter. Should be a killer!
Markoz28 is offline   Reply With Quote
Old 02-20-2020, 08:27 AM   #4
jmackisback
Thanks for in input guys, I appreciate it. Still looking for that 18% part number
1987 Camaro V6
1988 Camaro IROC Z
1993 Camaro Z28
1999 Camaro SS
2017 Camaro SS
Old 02-20-2020, 11:16 AM   #5
JasonSB
Drives: 2018 ZL1
https://dsxtuning.com/collections/su...12859884372048
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
JasonSB is offline   Reply With Quote
Old 02-20-2020, 02:32 PM   #6
Markoz28
Originally Posted by JasonSB View Post
Well this should be the answer then.
Hey Jason what part of Tx are you in?
Old 02-20-2020, 03:06 PM   #7
JasonSB
Drives: 2018 ZL1
I'm in the DFW area.
Old 02-20-2020, 05:16 PM   #8
jmackisback
Thanks kindly. I take it ATI and/or other brands don't make an 18%? (which basically appears to be a 9.5"?)
1987 Camaro V6
1988 Camaro IROC Z
1993 Camaro Z28
1999 Camaro SS
2017 Camaro SS
Old 02-20-2020, 07:37 PM   #9
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
I got a 9.17in lower pulley and balancer that is 17% not sure of an 18%
Zigg L1 is offline   Reply With Quote
Old 02-20-2020, 08:46 PM   #10
jmackisback
I was under the impression a 9.17 was 15%, am I mistaken?
1987 Camaro V6
1988 Camaro IROC Z
1993 Camaro Z28
1999 Camaro SS
2017 Camaro SS
Old 02-20-2020, 10:11 PM   #11
Markoz28
No, you are correct. 9.17 on the lt4 is a 14-15% but on the LSA an 18%.
Old 02-21-2020, 06:49 AM   #12
jmackisback
Recommendations for pulley size with a CAI, headers and dial nozzle meth set up?
1987 Camaro V6
1988 Camaro IROC Z
1993 Camaro Z28
1999 Camaro SS
2017 Camaro SS
Old 02-21-2020, 07:25 AM   #13
Markoz28
If porting the stock SC, change the upper to 2.1 pulley would net you 14%. If not do the lower pulley 9.17.
I ported my SC and run dual meth with 2.3 upper and 9.17 lower. Added the upper bc of the better flow from the SC now and to maintain boost. Some would say that it’s too much and the SC will heat soak. I don’t run back to back as I like everything to cool down from Diff to trans so I don’t mind waiting 30-45min between runs.
Old 02-21-2020, 10:39 AM   #14
Zigg L1
Zigg L1's Avatar
DSX makes a 9.45in lower which is 18%. Got mine from Vengeance Racing
