02-19-2020, 01:22 PM | #1 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Katech ZL1 Stage 4, Serial 010
Just received this beautiful Bright Yellow Camaro ZL1 at the shop. It will be getting our Stage 4 package for the automatic transmission. Haven't seen a whole lot of this color, I must say it looks very good in person.
I wanted to share the whole process with the forum from start to finish on one of our most popular packages that we sell. We have tons of Stage 4 LT4 builds floating around in the Corvette world, we all know that Camaros have the potential to be on top All of our valvetrain packages are spintron validated with a 1000 RPM factor of safety, you will never have to worry about dropping a valve or having any sort of valvetrain instability. Our Stage 4 includes: -Katech Billet Valley Cover, AFM Delete -ARP Head Studs -New LT4 Head Gaskets -Katech K-Force 2 Camshaft -Tool Steel VVT Lockout -OEM GM Cam Bolt -PSI 1511 Valve Springs -Katech CNC Ported Heads -Katech CNC Ported Chambers -Katech Competition Valve Job -Katech Hand Blend Valve Job to Chambers/Port -Katech Tool Steel Intake Retainers -Katech Tool Steel Exhaust Retainers -Katech Tool Steel Spring Seats -Trend 3/8 0.080 Hardened Steel Pushrods -OEM Crank Bolt -New LS7 Lifters -New GM Lifter Trays -Katech C5.R Timing Chain -Katech Blue Viton Valve Seals -Katech Spark Plug Wire Insulators -Brisk Racing Spark Plugs -Rotofab Big-Gulp Intake -Katech 103mm Throttlebody -Griptec Supercharger Upper Pulley -Griptec Supercharger Upper Hub -ATI Damper, LT4 -ATI Damper, 14% Overdrive -Gates Heavy Duty Serpantine Belt -New OEM Cradle Bolts -New Coolant (GM Dexcool) -New Oil (Mobil1 0w-40) -New OEM Filter -AP600 Brake Fluid -New GM Flywheel Bolts -Baseline Dyno -Street Calibration -Chassis Dyno Calibration -Katech Serialized Plaque with our 3 year, 36,000 mile warranty. Stay tuned for more, cheers. |
02-19-2020, 01:48 PM | #2 |
I’m tuned in Zach!!
02-19-2020, 02:37 PM | #3 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
What fuel lobe on the cam? 38% ?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
02-19-2020, 03:10 PM | #4 |
02-20-2020, 08:41 AM | #5 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
No ported blower on the list?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
02-20-2020, 08:50 AM | #6 |
Drives: 2018 ZL1 A10 Join Date: Sep 2014
I was wondering the same thing.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors 1994 Trans Am LM7/CPT 4L60E/9" 1987 IROC 2006 Silverado |
02-20-2020, 09:07 AM | #7 |
Drives: 2019 ZL1 Join Date: Oct 2019
In to follow!
Katech_Zach do you have any dynos of your Magnuson 2300 swap only package (the one that is 8kish for a 2019+ A10 ZL1). You list 750hp but curious what those put down SAE, figured 650ish whp / 650tq. |
02-20-2020, 09:42 AM | #8 |
Drives: 2019 Zl1 Camaro. Join Date: Jan 2020
Can't wait! Beautiful color as well.
02-20-2020, 09:45 AM | #9 |
How about anything to deal with the additional heat?
2018 ZL1 - Garnet Red, NO Sunroof, A10, PDR, Carbon hood insert = Perfect
02-20-2020, 11:19 AM | #10 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Yep, didn't see any cooling upgrades, either!
02-20-2020, 11:49 AM | #11 |
No additional cooling upgrades at the moment, it is 100% a street car. We also do not overspin the blower, so IAT's and head temps stay relatively cool.
02-20-2020, 12:29 PM | #12 |
02-20-2020, 10:44 PM | #13 |
Drives: Grandad's C2 L89 Join Date: May 2017
2018 ZL1 1LE sw/PDR
02-22-2020, 12:56 PM | #14 |
Drives: Chevy zl1 1le Join Date: Nov 2019
