Old 02-15-2020, 09:07 AM   #1
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
SE1014, 72 mm (76 mm Eff.) for Camaro 6 NA 3.6L V6 (LGX)
Hello, Everyone.
Soler Performance LLC, is happy to announce that after being carefully designed, manufactured, and extensively road-tested; our LGX Modified Throttle Bodies are now available.
Please visit: https://www.solerengineering.com/sto...skuv9x0dxm6dsi
Here is a quick summary:
$325 (New), $225 (Exchanges or Reworking your own stock TB)
We used the same proven approach that made our LT1/LT4/LT5 so successful.
FEATURES:
• Optimized Active Contours with sonic flow nozzles
• Porting Taper and Upstream Bore with Velocity Stack (Lip & Bore Reduction)
• Greater Discharge Coefficient of Plate/Blade interface
• 16 Ra Microinch, Diamond Polished Surface Finish (Lower Skin Friction)
• Shaftless high-pressure side of the blade for Larger WOT Flow Area (76 mm Effective Bore)
• Self-Cleaning Throat/Flow Gap
• Dome and Thread-locked Screws • Made from Brand New OEM Parts
BENEFITS:
• Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience
• Linearization and smoothing of the curve for a more predictable response and crisper shifts
• Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning. Warranty safe.
• More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
• Easy Installation (15 Minutes or Less)
Thanks,
Tiffany,
support@solerengineering.com
(251) 468-9786
Last edited by Mike@SolerPerformanceLLC; 02-15-2020 at 09:43 AM. Reason: typo, added pics
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 02-17-2020, 07:48 AM   #2
RxSummit16
Drives: 2016 Summit White Camaro LT2 RS
Great news! Who's gonna be first? lol
2016 Camaro 2LT | 3.6L V6 | A/T | Summit White | JWM Smoked Side Markers | Flowmaster American Thunder Axle-back Exhaust | K&N Filter | AIRAID Modular Intake Tube | Overkill Tune
RxSummit16 is offline   Reply With Quote
Old 02-17-2020, 09:06 AM   #3
Ha, no problem there. Do you mean the 4th? It has been engine/road tested already for longer than two months.
Besides, with us, there is no risk. 30-day money-back warranty followed by 11-month repair or replacement. Free shipping both ways.
Thanks,
Tiffany,
(251) 468-9786
Old 02-17-2020, 05:02 PM   #4
dgriff14
waddupdgriff
dgriff14's Avatar
Drives: Supercharged 2016 2LT RS
So only NA vehicles, eh?
2016 Chevrolet Camaro 2LT RS
• Edelbrock E-Force Stage 1 Supercharger • Custom tune by Overkill Motorsports • AFE Momentum GT Pro Dry Cold Air Intake • MBRP SS Cat Back Exhaust • iROC-z Wheels • Nitto NT555 G2 Tires (275 fronts, 305 rears)
dgriff14 is offline   Reply With Quote
Old 02-17-2020, 05:24 PM   #5
chevyracingfan
chevyracingfan's Avatar
Drives: 2018 camaro ls 1le
time to start saving $$
chevyracingfan is offline   Reply With Quote
Old 02-17-2020, 06:22 PM   #6
No, you can also use it on vehicles fitted with aftermarket forced induction. The NA refers to the OEM form of the engine.
Very good point though, we'll probably remove that as it is something owners usually know, and it is not needed to make a decision on fitment. Definitely redundant.
Thank you!
Tiffany,
(251) 468-9786
Old 02-17-2020, 06:47 PM   #7
JakeF_RS
Drives: Camaro
This would be a great option for people who're going supercharged or those who aren't wanting to do the 80mm TB/ported manifold combo.
JakeF_RS is offline   Reply With Quote
Old 02-17-2020, 07:40 PM   #8
dgriff14
waddupdgriff
dgriff14's Avatar
Thank you!
All good! Lol you cleared it up
Old 02-17-2020, 07:41 PM   #9
dgriff14
waddupdgriff
dgriff14's Avatar
Supercharged here. But I have the top mounted edelbrock kit so I don’t even have my original manifold anymore. Seems like we’re on the same wavelength lol
Old 02-20-2020, 07:57 AM   #10
BOYD3800SII
Drives: 2017 RS CAMARO V6
Hello, Everyone.
FEATURES:
BENEFITS:
Thanks,
So I can send in my old TB and you will provide a completed unit or will I get my own reworked unit back. Either way the price sounds great!
BOYD3800SII is offline   Reply With Quote
Old 02-20-2020, 08:55 AM   #11
Thanks for asking:
Exchange: You order and pay a deposit. Part ships to you right away. Once you get it, you'll ship your stock unit, and the deposit is refunded. Your car has no downtime.
Reworking you Own TB: You order (no deposit). You ship your stock unit, we'll rework it in one or two days max, and ship back to you. This is the same unit you sent. A better option if you have a newer unit (lower mileage).
Either way, your total is $225 after it is all completed. Same warranty.
Tiffany,
(251) 468-9786
Old 02-20-2020, 10:16 AM   #12
BOYD3800SII
Thanks for asking:
Thanks MIKE! I placed my order online! I am excited to see the performance!
Old 02-20-2020, 12:27 PM   #13
Thank you much, BOYD. It is on the way, at your door hopefully Saturday.
Tiffany,
(251) 468-9786
Old 02-22-2020, 04:37 PM   #14
BOYD3800SII
Wow it works as advertised! I got it and installed it. Took a test drive and I feel immediate throttle response in first gear. IT PULLS HARD in the upper RPM range and I got up to 60MPH really quick! Thanks a ton Mike!
