Old 02-14-2020, 05:11 PM   #1
MSU120
Drives: 2018 1SS 1LE
Texas Speed cats/FI
Has anyone used the Texas Speed headers with their cats on a FI car? If so....have they held up? I won’t be pushing anything above 600ish rwhp when it’s all said and done.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD
MSU120 is offline   Reply With Quote
Old 02-14-2020, 05:45 PM   #2
oldman
Drives: SS 6 speed of course
I ran the standard Kooks cats on my car, many hard runs through the gears never had any issues, the TS cats look similar. IMO, the guys that are running rich mixtures of meth / eth which can go as low as 5:1 A/F max rich power are injecting a whole lot more thermal heat load into the exhaust than what you are doing. i.e. the ultrarich mixtures that can be run are not completely burnt and the combustion continues on the cat substrate (which it was designed for) and that just means it gonna get heck of hot heck of fast.
Old 02-14-2020, 05:52 PM   #3
MSU120
Thank you. I had the standard Kooks cats on my G8 (FI) and never had an issue either.
Old 02-14-2020, 08:49 PM   #4
Robby23
Drives: 2018 1SS M6
I have seen threads in the forced induction section of people saying they burn up their cats. Although I think they were pushing higher numbers like 650-700+. I would read around in there a little bit or ask in that section.
Robby23 is offline   Reply With Quote
Old 02-14-2020, 11:28 PM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Shouldn't be a issue at your power level.
Old 02-18-2020, 02:29 AM   #6
AD17SS1LE
AD17SS1LE's Avatar
Drives: 2017 Camaro SS 1LE
I have the TSP 1 7/8" long tube headers with catted connection pipes, be advised they don't have any 02 bungs in the cats, you will need the catted x pipe if you want the downstream 02 sensors functional, or you can make your own bung in the catted connection pipe.
2017 Camaro SS 1LE
Pray ported TB/IM
TSP 1 7/8 Long tube headers w catted con pipes
Taylor plug wires
Mishimoto oil cooler
Elite X2 catch can
AD17SS1LE is offline   Reply With Quote
Old 02-18-2020, 06:16 AM   #7
L78toLT1
L78toLT1's Avatar
I'm in the mid 700's on standard Kooks cats. No issues in 5k miles including several track days. I run e60 on track days and most of the time on the street.
Baby Blue
Old 02-18-2020, 07:16 AM   #8
DorkMissile
DorkMissile's Avatar
Drives: DZ
At 600-700whp there should be no problem running stock cats, being the LT4 cat is the same as the LT1 cat
DorkMissile is offline   Reply With Quote
Old 02-19-2020, 09:00 AM   #9
Juiced1
Drives: 2012 2SS CAMARO 45th
If you drive the car a lot or put the family in it we usually recommend cats up until about 700rwhp. After that they can go pretty quick but tuning plays into as well.
Juiced1 is offline   Reply With Quote
