Old 02-14-2020, 03:24 PM   #1
kdm123
Drives: 2018 ZL1-1LE
Power loss on track
I’m doing a track day and the engine power is cutting off
Nothing is over heating
The traction control and stability control are both fully off
An engine check light is on.
I tried dc the battery but on the first lap the problem continued
It doesn’t happen driving it on the street under full power
Any ideas?
kdm123 is offline   Reply With Quote
Old 02-14-2020, 03:36 PM   #2
staples87
Drives: 2017 Camaro ZL1
After the check engine light came in, did you drive it on the street and the light turned off, or is it permanently on now?
Any mods to the car or is it completely stock?
'17 Camaro ZL1 M6
staples87 is offline   Reply With Quote
Old 02-14-2020, 03:49 PM   #3
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Wasn’t there issues with air in the coolant system causing the engines to deface or go into limp mode?
I wonder if this is causing the car to drop power????
Old 02-14-2020, 04:15 PM   #4
kdm123
The engine light was off after the battery dc, but came back on on tge the first lap. It’s still on now.
No overheating
Old 02-14-2020, 04:18 PM   #5
kdm123
Car is totally stock
Old 02-14-2020, 04:32 PM   #6
ssrallyred
ssrallyred's Avatar
Drives: 2017 Summit White ZL1 M6
Get it scanned to see what the code is. then you probably have a starting point.
Roto Fab/ Kook's LT's,ported blower,removed lid baffle/ 103mm TB' lower pulley and tune.
651/660.
ssrallyred is offline   Reply With Quote
Old 02-14-2020, 07:04 PM   #7
Dixie ZL1
NOXQCES ZL1
Suspect your SC cooling system has air in it and needs to be bled.
Dixie ZL1 is offline   Reply With Quote
Old 02-14-2020, 11:00 PM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
scan for the code and go from there
Old 02-17-2020, 11:47 AM   #9
kdm123
I'm taking it to the dealer Friday.
Unfortunately the problem isn't happening in street driving. I hope they can figure it out at the dealer because it really sucks to do all the preparation and cost for a track day only to go home after 2 laps!
The power was cutting out intermittently like when you have fuel starvation, though it could have been ignition just as well. No overheating of any kind.
