Old 02-14-2020, 08:04 AM   #1
crosive
Drives: 18 zl1
holding left paddle
I'm sure most know this will downshift the a10 to the most viable gear.
however, are there things that would prevent this? the last few times I've tried it, in sport or track, manual mode, the car just wouldn't do it.
the only thing that stands out to me, is the tires are "cool" according to the display. proper tire pressure, car is warmed up, no cruise control. I'm stumped as to why it won't do it.
I've not checked for stored codes, but the car has never thrown one up that I've seen
crosive is offline   Reply With Quote
Old 02-14-2020, 10:21 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
The car has to be in M (manumatic), not D (full auto).
Old 02-14-2020, 10:51 AM   #3
TWG1
TWG1
Drives: 2019 Camaro ZLE
I’ve found that a quick tap (downshifts -1, and brings you to M mode temporarily), followed by a hold will get you the max downshift. Think “single tap-hold”.
That said, I really haven’t found a use for this Easter egg. RPMs are so high it doesn’t give me much room for a run, and engine breaking so heavy I’m likely on the brakes anyway.
That said, I use the floor tap to PSM ALL THE TIME though. That’s a great feature for me, both in decel for an off ramp, or prep to accelerate (onramp, etc)
2019 ZLE M6
2019 ZL1 A10 (Sold)
1967 Jaguar XKE Series 1 Roadster
2021 F150 Powerboost (on order)
TWG1 is offline   Reply With Quote
Old 02-14-2020, 10:56 AM   #4
crosive
Drives: 18 zl1
Still didn't work in manual mode
Old 02-14-2020, 10:57 AM   #5
crosive
Drives: 18 zl1
Originally Posted by TWG1 View Post
I’ve found that a quick tap (downshifts -1, and brings you to M mode temporarily), followed by a hold will get you the max downshift. Think “double tap-hold”.
I tried that inadvertently. Holding didn't shift all the way, just 1 gear, but holding again right after just gave another gear.
Old 02-14-2020, 01:54 PM   #6
joe944
joe944's Avatar
Drives: 18' A10 ZL1 , 18' F150, 04' MSM
I'm guilty of using this a lot. I haven't done the paddle hold since I first got the car, but I'll use the floor tap for PSM for decel in traffic sometimes.
joe944 is offline   Reply With Quote
Old 02-14-2020, 02:24 PM   #7
The issue you are having is your foot is still on the accelerator.
Even the slightest little bit will cause it not to activate.
One thing I used to do was use the accelerator to activate... I would hold the left paddle down and then release the gas pedal when I was ready. It would drop from 10th gear to 3rd at 80 mph
As mentioned you are so close to redline at this point that once you go WOT you have to be ready to shift very quick or slap the shifter quickly back to auto and keep going. Definitely takes a lot of practice and you can screw up a good roll run pretty quick with this method.
Old 02-14-2020, 05:00 PM   #8
crosive
Drives: 18 zl1
Ok. This makes sense. I didn't know you couldn't do it while "cruising".
I was trying to maintain speed since obviously going from 10-3 will drop speed quick.
Old 02-14-2020, 05:11 PM   #9
So that's why simply holding it down it wasn't working for me either. I could, however, downshift once (to activate M mode) and then hold down the paddle for the lowest gear downshift even while keeping the accelerator steady.
I will definitely try this "activation trick" once she comes out of hibernation, just to see if it is more usable on the A8, thanks mlee
Old 02-14-2020, 07:24 PM   #10
URBAN LEGEND
URBAN LEGEND's Avatar
On my 19 A10 in manual mode all I do is hold the left paddle and it downshifts to be lowest gear under decel and braking.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 02-14-2020, 09:32 PM   #11
The way it should work...
The magazine reviews early on wrote about this feature being buggy and only worked once in a while. The gas pedal was their issue too.
Old 02-15-2020, 10:19 AM   #12
collinms
Drives: 2017 ZL1 A10 Summit White
Have to be off the gas while holding.
collinms is offline   Reply With Quote
Old 02-15-2020, 09:30 PM   #13
You can actually be on the gas while holding but as soon as you get off the gas it will activate.
Old 02-15-2020, 11:59 PM   #14
mlee, how did you find out about this? Did you experiment or is this behavior documented somewhere?
